Bug of IMFS_unlink ?
Fri Aug 22 13:49:33 UTC 2008
Wei Shen wrote:
> Hi,
> I suspect there is a bug with unlink of IMFS files, but I am not certain.
> If a file is still being opened, IMFS_unlink will not really free the
> file node, but just decrements its link count and removes it from the
> parent's chain, and the remaining work is leaved to close.
> memfile_close calls memfile_check_rmnod to delete the file node with a
> zero link count when the last user closes the file.
> However, in memfile_check_rmnod "rtems_libio_is_file_open" is checked,
> which it will always be TRUE because the LIBIO_FLAGS_OPEN flag bit has
> not been cleared yet. Hence, the file node will never be deleted,
> while it can no more be accessed in the file system.
Can you provide a simple test case and let me analyze it?
> I also wonder why device_close and imfs_dir_close do not do similar
> rmnod checks as memfile_close.
Looks to me that the generic close should be detecting this
condition and (maybe) calling the specific filetype for unlink.
What do you think of that?  Again I think it will take a test
case to verify and fix.
> Regards,
> Wei
> rtems-users mailing list
> rtems-users at rtems.com
