rtems 4.9 build failure due to new unistd.h
Gene Smith
gds at chartertn.net
Mon Dec 8 07:45:16 UTC 2008
I recently tried to do a "make clean all" of rtems and it fails when
compiling ttyname.c: ttyname_r() with a complaint that it differs from
the declaration in unistd.h. ttyname_r() has parameter namesize
declared as int while in unistd.h it is size_t and declared only for
cygwin and rtems.
I think unistd.h (under /opt/rtems-4.9/arm-rtems4.9/include/sys) was
recently yum updated since on another machine which has not been
recently updated it only declares ttyname_r() in unistd.h for cygwin and
not for rtems, so there is no conflict.
Anyhow, I ended up changing namesize from int to a size_t in
rtems-4.9.0/cpukit/libcsupport/src/ttyname.c.
-gene
P/S:
It seems that namesize is not actually used in posix function
ttyname_r(). Also, is "Demetermine" a real word?
