gcc build fails "cannot compute suffix of object files"
chenyulongrtems
chenyulongrtems at 163.com
Wed Dec 10 06:28:39 UTC 2008
Hi all !
I'm building arm toolchain for rtems-4.10, when building gcc-4.3.2 I meet a problem .
My pc is RHEL4 , and my sources is :
binutils-2.19-rtems4.10-20081023.diff
binutils-2.19.tar.bz2
gcc-core-4.3.2-rtems4.10-20081119.diff
gcc-core-4.3.2.tar.bz2
newlib-1.16.0.cvs.20081127-rtems4.10-20081127.diff
newlib-1.16.0.cvs.20081127.tar.gz
when make gcc it fails as:
make[1]: Entering directory `/opt/rtems/tools/b-gcc'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/libiberty'
make[3]: Entering directory `/opt/rtems/tools/b-gcc/libiberty/testsuite'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/opt/rtems/tools/b-gcc/libiberty/testsuite'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/libiberty'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/fixincludes'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/fixincludes'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/intl'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/intl'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/libiberty'
make[3]: Entering directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/libiberty/testsuite'
make[3]: Leaving directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/libiberty/testsuite'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/libiberty'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/fixincludes'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/build-i686-pc-linux-gnu/fixincludes'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/libcpp'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/libcpp'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/libdecnumber'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/libdecnumber'
make[2]: Entering directory `/opt/rtems/tools/b-gcc/gcc'
make[2]: Leaving directory `/opt/rtems/tools/b-gcc/gcc'
Checking multilib configuration for libgcc...
Configuring in arm-rtems4.10/libgcc
configure: loading cache ./config.cache
checking for --enable-version-specific-runtime-libs... no
checking for a BSD-compatible install... /usr/bin/install -c
checking for gawk... gawk
checking build system type... i686-pc-linux-gnu
checking host system type... arm-unknown-rtems4.10
checking for arm-rtems4.10-ar... /opt/rtems/rtems-4.10//arm-rtems4.10/bin/ar
checking for arm-rtems4.10-lipo... arm-rtems4.10-lipo
checking for arm-rtems4.10-nm... /opt/rtems/tools/b-gcc/./gcc/nm
checking for arm-rtems4.10-ranlib... /opt/rtems/rtems-4.10//arm-rtems4.10/bin/ranlib
checking for arm-rtems4.10-strip... /opt/rtems/rtems-4.10//arm-rtems4.10/bin/strip
checking whether ln -s works... yes
checking for arm-rtems4.10-gcc... /opt/rtems/tools/b-gcc/./gcc/xgcc -B/opt/rtems/tools/b-gcc/./gcc/ -nostdinc -B/opt/rtems/tools/b-gcc/arm-rtems4.10/newlib/ -isystem /opt/rtems/tools/b-gcc/arm-rtems4.10/newlib/targ-include -isystem /opt/rtems/tools/gcc-4.3.2/newlib/libc/include -B/opt/rtems/rtems-4.10//arm-rtems4.10/bin/ -B/opt/rtems/rtems-4.10//arm-rtems4.10/lib/ -isystem /opt/rtems/rtems-4.10//arm-rtems4.10/include -isystem /opt/rtems/rtems-4.10//arm-rtems4.10/sys-include
checking for suffix of object files... configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details.
make[1]: *** [configure-target-libgcc] Error 1
make[1]: Leaving directory `/opt/rtems/tools/b-gcc'
make: *** [all] Error 2
In config.log, I then see:
configure:4083: g++ -c -g -O2 conftest.cc >&5
conftest.cc: In function `int main()':
conftest.cc:13: error: `exit' undeclared (first use this function)
conftest.cc:13: error: (Each undeclared identifier is reported only once for each function it appears in.)
configure:4089: $? = 1
configure: failed program was:
| /* confdefs.h. */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| /* end confdefs.h. */
| int
| main ()
| exit (42);
| return 0;
Any ideas about what I need to fix?
Thanks,
URL: <http://lists.rtems.org/pipermail/users/attachments/20081210/e8d72a8a/attachment.html>
