A problem when using printf in timer routine
PowerMan
powerman1st at gmail.com
Tue Dec 16 11:16:09 UTC 2008
I used a app-timer in my program and encountered a problem, the service
routine is
static rtems_timer_service_routine timer_show(rtems_id tid, void *pdat)
led1_on();
printf("%x\n", tid);
led2_on();
led1_on is ok, but the printf didn't return, so led2_on failed.
My platform is s3c2410(arm920t), rtems-4.7.3, and the bsp is based on
gp32(s3c2400).
Because I made only a little change to the bsp of gp32, I guess this bug is
not
my fault. Somebody please help me.
I know the rtems-4.9.1 had support smdk2410, but my board have
a lot of differences with it.
Somebody who have smdk2410 please try the following application and report
the result to me. Thanks.
On my board, "aa" is printed, but "bb" isn't.
#include <bsp.h>
#include <rtems/bspIo.h>
static rtems_id timer_id;
static rtems_name timer_name;
static const char timer_name_s[8] = "tmr0";
printk("aa");
printf("bb");
printk("cc");
static int init_timer(void)
/* build object name for timer */
timer_name = rtems_build_name(timer_name_s[0], timer_name_s[1],
timer_name_s[2], timer_name_s[3]);
/* create timer */
if (rtems_timer_create(timer_name, &timer_id) != RTEMS_SUCCESSFUL) {
fprintf(stderr, "failed to create timer\n");
return 0;
/* fire after 5 seconds */
rtems_timer_fire_after(timer_id, 500, timer_show, NULL);
return 1;
rtems_task Init(rtems_task_argument argument)
if (!init_timer()) {
fprintf(stderr, "failed to init timer\n");
exit(0);
for (;;);
if (rtems_task_delete(RTEMS_SELF) != RTEMS_SUCCESSFUL) {
fprintf(stderr, "failed to delete init-task\n");
exit(0);
/**************** START OF CONFIGURATION INFORMATION ****************/
#define CONFIGURE_INIT
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 10
#define CONFIGURE_MAXIMUM_TIMERS 10
#define CONFIGURE_TICKS_PER_TIMESLICE 10
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
#include <rtems/confdefs.h>
/**************** END OF CONFIGURATION INFORMATION ****************/
URL: <http://lists.rtems.org/pipermail/users/attachments/20081216/ad30ea5d/attachment.html>
