4.9.0 with shell via telnetd - new telnetd issue?
Robert S. Grimes rsg at alum.mit.edu
Thu Dec 18 23:11:02 UTC 2008
Gene Smith wrote:
> Alan,
> Thanks for the code. To get a simple telnetd/pty to work in 4.9 I had to
> add/remove a few new things to my Init() marked below with + and -
> compared to 4.8. The key seems to be adding "NEEDS_LIBBLOCK" (link
> errors without) and reserving the dummy slot in the Device_drivers[]
> array for later addition of pty driver (PTY_DRIVER_TABLE_ENTRY causes
> link error to pty routines). So now I can telnet in again. Thanks for
> the pointers!
> -gene
> #include <bsp.h>
> #include <rtems/pty.h>
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 20
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_EXECUTIVE_RAM_SIZE (512*1024)
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
> #define CONFIGURE_MAXIMUM_TASKS      20
> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
> #define CONFIGURE_INIT_TASK_PRIORITY   120
> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>                                             RTEMS_NO_TIMESLICE | \
>                                             RTEMS_NO_ASR | \
>                                             RTEMS_INTERRUPT_LEVEL(0))
> #define CONFIGURE_MAXIMUM_POSIX_TIMERS 5  /* tbd gds: XXX */
> #define CONFIGURE_MAXIMUM_TIMERS 5
> +#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK   /* for telnet shell */
> -/*#define CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE*/
> #ifndef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
>         #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>         #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +       #define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER  /* pty here! */
> #else
>         rtems_driver_address_table Device_drivers[] = {
>             CONSOLE_DRIVER_TABLE_ENTRY,
>             CLOCK_DRIVER_TABLE_ENTRY,
>             PTY_DRIVER_TABLE_ENTRY  /* link fails */
> #endif
> #define CONFIGURE_MAXIMUM_PTYS 2
> rtems_task Init (rtems_task_argument argument);
> #include <rtems/confdefs.h>
> +/* needed for pty/telnetd? */
> +#define CONFIGURE_SHELL_COMMANDS_INIT
> +#define CONFIGURE_SHELL_COMMANDS_ALL
> +#include <rtems/shellconfig.h>
> #include <stdio.h>
> #include <stdlib.h>
> #include <rtems/rtems_bsdnet.h>
> #include "networkconfig.h"
> #include <rtems/telnetd.h>
> void rtemsShell( char *pty_name, void *cmd_arg)
>      rtems_shell_main_loop( NULL );
> #define SHELL_ENTRY rtemsShell
>   * RTEMS Startup Task
> rtems_task
> Init (rtems_task_argument ignored)
>      rtems_bsdnet_initialize_network ();
>      rtems_bsdnet_show_inet_routes ();
> -    /*rtems_telnetd_initialize(); ---- harder with 4.9 */
>       * Starting the telnetd server
> +    printf("Starting the telnetd Server.\n");
> +    rtems_telnetd_initialize(
>          SHELL_ENTRY,               /* "shell" function */
>          NULL,                      /* no context necessary for echoShell */
>          FALSE,                     /* spawn a new thread */
>          RTEMS_MINIMUM_STACK_SIZE * 20,  /* shell needs a large stack */
>          1,                         /* priority .. we feel important
> today */
>          0                          /* do not ask for password */
> <snip>
> } /* END Init() */
> Alan Cudmore wrote:
>> This is what I use for telnetd and the shell in 4.9:
>>   void rtemsShell(
>>     char *pty_name,
>>     void *cmd_arg
>>    ** Starting the telnetd server
>>        1,                         /* priority .. we feel important today */
>> Alan
All,
Okay, I got it working, following Alan's example, plus "LD_LIBS +=
-ltelnetd", plus this:
as noted by Gene.  I didn't have to make the other changes, Gene, but then again, I had some things already - like NEEDS_LIBBLOCK.
However, when I say ugly, this is what I see.
    Welcome to rtems-4.9.0(PowerPC/Generic (no FPU)/virtex)
    COPYRIGHT (c) 1989-2008.
    On-Line Applications Research Corporation (OAR).
    Login into RTEMS
    login: rrtteemmss
    Password:
    RTEMS SHELL (Ver.1.0-FRC):. Sep 26 2008. 'help' to list commands.
Note the login response - what I typed was this "rtems<cr>", where "<cr>" is the enter key.  While it at first glance looked like local echo is on, notice that I only hit the enter key _once_, yet the shell has seen two; the second is consumed by the Password prompt.  So what gives?  Seems like something with telnetd - how do I fix this?  I'm sure it is something trivial, yet rather important...
Thanks,
-Bob
