QEMU/GRUB: No multiboot header found
Massimo Tipaldi mtipaldi at cgspace.it
Tue Dec 23 10:45:49 UTC 2008
Ok, I have followed your suggestions. Lets sort out at first the Rtems
compilation issue.
I have reinstalled Rtems tools in /d/opt/rtems-4.9 (Rtems tools 4.9 with
the Autoconf & Automake + target i386).
After that, in the MSYS shell, I have typed the following sequence of
commands:
export PATH=/d/opt/rtems-4.9/bin:$PATH
mkdir -p /d/opt/src/rtems
cd /d/opt/src/rtems
tar jxf rtems-4.9.1.tar.bz2
cd rtems-4.9.1
./bootstrap
cd ..
mkdir i386
../rtems-4.9.1/configure --target=i386-rtems4.9 --enable-multilib
--prefix=/d/opt/src/rtems/i386
During the configuration phase, two messages are appeared:
./config.status:
libnetworking/netinet/.deps/libnetworking_a-if_ether.Po: No such file or
directory
./config.status: libmisc/mw-fb/.deps/mw_fb.Po: No such file or directory
After the configuration phase, in spite of these two messages, I have
tried the make:
make RTEMS_BSP="pc386"
After several minutes, the make fails with the following messages:
make[8]: Leaving directory
`/d/opt/src/rtems/i386/i386-rtems4.9/m486/soft-float/cpukit/libfs'
Making preinstall in libnetworking
make[8]: Entering directory
`/d/opt/src/rtems/i386/i386-rtems4.9/m486/soft-float/cpukit/libnetworking'
Makefile:1257: netinet/.deps/libnetworking_a-if_ether.Po: No such file
or directory
make[8]: *** No rule to make target
`netinet/.deps/libnetworking_a-if_ether.Po'.  Stop.
make[7]: *** [preinstall-recursive] Error 1
make[7]: Leaving directory
`/d/opt/src/rtems/i386/i386-rtems4.9/m486/soft-float/cpukit'
make[6]: *** [preinstall-stamp] Error 2
make[6]: Leaving directory
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory
make[4]: *** [all] Error 2
make[4]: Leaving directory
make[3]: *** [multi-do] Error 1
make[3]: Leaving directory `/d/opt/src/rtems/i386/i386-rtems4.9/cpukit'
make[2]: *** [all-multi] Error 2
make[2]: Leaving directory `/d/opt/src/rtems/i386/i386-rtems4.9/cpukit'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/d/opt/src/rtems/i386/i386-rtems4.9/cpukit'
make: *** [all-recursive] Error 1
At this stage, I have had a mistake related to the file
libnetworking_a-if_ether.Po.
As you can see, I have followed completely the instuctions of the RTEMS
wiki without renemaing any files.
Massimo
Joel Sherrill ha scritto:
> Chris Johns wrote:
>> Massimo Tipaldi wrote:
>>> Dear Joel,
>>> I have followed your suggestions, but unfortunately the same
>>> behaviour is observed.
> The file hello.ralf should have had bin2boot run on it.
> All of Chris' comments also apply.  Please use 4.9.1
> or the CVS head with matching tools.
>>> In any case, I would like to point out some important points:
>>> 1) to compile RTEMS, in the directory /d/opt/rtems-4.9/bin, I was
>>> obliged to rename all the files in order to remove the version number
>>> (for instance, i386-rtems4.9-g++.exe --> i386-g++.exe).
>> This is wrong and should not be done. It usually means you have not
>> configured RTEMS correctly. The Wiki entry:
>> http://www.rtems.org/wiki/index.php/MinGW_Tools_for_Windows#Building_RTEMS
>> says:
>>   ../rtems-4.9.0/configure --target=m68k-rtems4.9 --enable-multilib \
>>    --prefix=/c/opt/src/rtems/m68k
>> Please note the version number. Could you please try a configure this
>> way ?
>>> 2) to produce my Hello Word, I have updated the Makefile.inc
>>> (/d/opt/rtems-4.9/build-rtems/i386/c/pc386/make):
>>> prefix = /d/opt/rtems-4.9/build-rtems/i386/c/pc386
>>> exec_prefix = /opt/rtems-4.9/i386-rtems
>>> CC_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-gcc --pipe
>>> -I/d/opt/rtems-4.9/build-rtems/i386/pc386/lib/include
>>> CXX_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-g++
>>> AS_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-as
>>> AR_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-ar
>>> NM_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-nm
>>> LD_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-ld
>>> SIZE_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-size
>>> OBJCOPY_FOR_TARGET = /d/opt/rtems-4.9/bin/i386-objcopy
>>> CC= $(CC_FOR_TARGET)
>>> CXX= $(CXX_FOR_TARGET)
>>> AS= $(AS_FOR_TARGET)
>>> LD= $(LD_FOR_TARGET)
>>> NM= $(NM_FOR_TARGET)
>>> AR= $(AR_FOR_TARGET)
>>> SIZE= $(SIZE_FOR_TARGET)
>>> OBJCOPY= $(OBJCOPY_FOR_TARGET)
>>> PROJECT_TOOLS = /d/opt/rtems-4.9/build-rtems/i386/pc386/build-tools
>>> export PROJECT_TOOLS
>>> 3) inside the MSYS shell, before launching the make command, I have
>>> carried out the following:
>>> export
>>> RTEMS_MAKEFILE_PATH=/d/opt/rtems-4.9/build-rtems/i386/c/pc386/make
>>> export ARCH=/d/opt/rtems-4.9/examples-4.9.1/hello_world_c
>>> After that I have launched the make command in the folder:
>>> My Hello Word is successfully compiled, but it is not correctly
>>> managed by  QEMU ("No multiboot Header found").
>>> What I can further add, is that the dimension of my Hello Word is 17
>>> Kb, whereas the dimension of the Hello Word that comes from the RTEMS
>>> compliation is about 1 Mb.
>>> Does it sound strange? Should I modify the makefiles further in order
>>> to produce an executable file in line with the rtems boot loader
>>> multiboot specification? Can you suggest me something else?
>> I would rather you go back and try the correct configure command then
>> work though the build issues. Lets sort out one problem at a time.
>>> Thanks in advance and I wish you a Merry Christmas and Happy New Year.
>> Thanks and to you also.
>> Regards
>> Chris
>>> Massimo
>>>>> Dear all,
>>>>> I have installed all the RTEMS tools on Windows, compiled RTEMS 4.9
>>>>> (--target=i386-rtems and bsp=pc386) and installed QEMU as detailed in:
>>>>> http://www.rtems.com/wiki/index.php/MinGW_Tools_for_Windows
>>>>> http://www.rtems.com/wiki/index.php/QEMU
>>>>> All these operations went well.
>>>>> Therefore, I have tried to launch some RTEMS applications by means of
>>>>> QEMU/GRUB (in this phase I have taken the executable files produced
>>>>> during the RTEMS compilation phase, placed in /testsuites/samples):
>>>>> this
>>>>> operation was successfull as well.
>>>>> After that I have compiled successfully Hello Word by myself
>>>>> (examples-4.7.99.2.tar.bz2
>>>>> ftp://ftp.rtems.com/pub/rtems/4.7.99.2/examples-4.7.99.2.tar.bz2
>>>>> ) and put my hello.exe in the folder /testsuites/samples/hello).
>>>>> With my Hello Word, the GRUB gives me the message "No multiboot header
>>>>> found".
>>>> Very old examples.  Please use the ones which match 4.9.
>>>> This sounds like a bug which was fixed between 4.9.0 and 4.9.1.
>>>> 1337/bsps - Stripping .rodata section produces unusable executables
>>>> for the i386-rtems target.
>>>>> As far as I have understood, my hello.exe does not have a multiboot
>>>>> header.
>>>>> How can I overcome this issue? Should I modify somehow my source
>>>>> code or
>>>>> the makefiles in order to create this multiboot header into my .exe?
>>>>> Thanks in advance
>>>>> Massimo Tipaldi
Eng. Massimo Tipaldi
Technical Directorate
SW Principal Engineer
Carlo Gavazzi Space SpA
Via Tiengo, snc - 82100 Benevento BN - Italy
Tel: + 39 0824481733
Fax: +39 0824481730
e-mail: mtipaldi at cgspace.it
www.cgspace.it
<< Le informazioni contenute  in  questo messaggio  di posta elettronica
e relativi allegati sono  riservate  e confidenziali  e  ne  e vietata
la diffusione in qualunque modo eseguita. Qualora Lei non fosse la
persona a cui il presente messaggio e destinato, La invitiamo ad
eliminarlo e a darcene gentile comunicazione.Quanto precede ai fini del
rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196,
sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged.
If you have received it in error, you are on notice of its status.
Please notify us immediately by reply e-mail and then delete this
message from your system.  Please do not copy it or use it for any
purposes, or disclose its contents to any other person:  to do so could
be a breach of confidence.  Thank you for your co-operation.  Please
contact our IT Helpdesk on +3902380481 or email
ml_servizi.informatici at cgspace.it if you need assistance>>
