priority inherence bug?
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Dec 3 14:24:34 UTC 2008
xi yang wrote:
> On Wed, Dec 3, 2008 at 9:43 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> Thanks for the through answer.
>> I would only add that the default and historic behaviour
>> Manuel describes is documented and was selected
>> since it was a simple solution which did not require
>> tracking. See the third paragraph here.
>> http://www.rtems.org/onlinedocs//doc-current/share/rtems/html/c_user/c_user00162.html
>> We did not switch to strict order by default when it
>> was submitted because of two concerns. First as a change
>> to existing behaviour, it could have broken applications
>> in a subtle way. Second, it was new code and needed time.
> Sorry, I didn't update the onlinedocs when I submitted the patch.
It needs to be documented for sure. :(
> I think strict order may broke latency codes in two ways 1)It dosenot
> release mutex in LIFO order 2)It assumes that it still in a higher
> priority when it releases one of the mutex.
> For 1), Releasing mutex without LIFO order may leads to deadlock. So,
> breaking them is OK.
I think enforcing that the release order is the opposite
of the acquire order is OK. Bad programming practice to
do otherwise since it can lead to a deadly embrace.
> For 2), maybe some programmers read the manual and do it like that :)
I don't understand the issue for 2).
--joel
> Regards
>> It may be time to switch the default to using it and
>> getting time on the code so it is the default in 4.10.
>> We can then consider killing the old behaviour in 4.11.
>> It is important to be cautious when changing something like
>> this.
>> --joel
>> xi yang wrote:
>>> On Wed, Dec 3, 2008 at 7:51 PM, Manuel <manuel.coutinho at edisoft.pt> wrote:
>>>> Hi
>>>> We are doing some tests to RTEMS and have stumbled in a possible bug when
>>>> semaphores with priority inherence are used.
>>>> Suppose a low priority task obtains two semaphores with priority
>>>> inherence.
>>>> After it obtains the critical region, other higher priority tasks also
>>>> try
>>>> to obtain the semaphores.
>>>> We have tested that the priority of the lower priority task is correctly
>>>> raised to the priority of the highest priority task that tries to obtain
>>>> the
>>>> semaphore. However, when the low priority task releases the first
>>>> semaphore,
>>>> its priority should decrease (because the second semaphore is only used
>>>> by
>>>> middle priority tasks). The priority of the lower priority task is only
>>>> restored to its original when it released the two semaphores.
>>> So, you want that if the task releases the mutex as LIFO order, just
>>> restore the priority of the task to the previous priority. You can
>>> enable the strict order function. In
>>> rtems-4.9.0/testsuites/sptests/sp36/sp36.doc, it write
>>> This is a simple test program to demonstrate strict order mutex.
>>> 1)What's strict order mutex ?
>>> In rtems,when a task release a priority_inheritance or
>>> priority ceiling semaphore,the kernel detect whether
>>> this task holds priority_inheritance or priority
>>> ceiling semaphore, if not, set the priority of task
>>> back to real priority of task.
>>> This method is right, but in theory, we would like
>>> to reset the priority after releasing the mutex if
>>> releasing it in LIFO order.Do it like this can decrease
>>> the blocking time of a higher priority task .
>>> 2)How to enable "strict order mutex " ?
>>> When configuring the rtems , add
>>> ENABLE_STRICT_ORDER_MUTEX=1
>>> to your configure parameter.
>>> 3)About this test program
>>> T0,T1,S0,S1
>>> T0,priority 4
>>> T1,priority 1
>>> S0,priority inheritance
>>> S1,priority ceiling,priority ceiling 1
>>> 1,T0 obtain S0 then obtain S1, priority of T0 should be improved to 1
>>> 2,T0 try to release S0, but not in strict order, return error code
>>> 3,T0 release S1,the priority of T0 back to 4
>>> 4,T1 try to obtain S0
>>> 5,T1 should be blocked and the priority of T0 should be improved to 1
>>> 6,T0 release S0
>>> 7,T1 obtain S0
>>> 8,OVER.
>>> Regards
>>>> In our opinion, this is not the correct behavior of priority inherence
>>>> semaphores. We will try to correct this bug.
>>>> Kind regards
>>>> Manuel Coutinho
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D. Director of Research & Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
