problems with relocatable object files
Kate Feng
feng1 at bnl.gov
Tue Dec 9 14:25:08 UTC 2008
Till Straumann wrote:
> When you link your relocatable file (simplified) with
> gcc -r $(OBJECTS) -o myrel.o
> then gcc will implicitly link startfiles and 'default' libraries such as
> libc etc.
> Hope you didn't forget to add -nostdlib, i.e.,
> gcc -nostdlib -r $(OBJECTS) -o myrel.o
-nostdlib will bypass libgcc.a too. Usually, one needs to use
the libgcc.a even when one needs to avoid the standard libraries.
Thus, you might need to add -lgcc as well.
Cheers,
Kate||
> HTH
> -- Till
> rtwas wrote:
>> Hello,
>> I'm trying to move my build tree to the *rtems* was of doing things. Our
>> project is rather large so
>> we link using "-r" for later linking into the final executable. It
>> (relocatable object) compiles and links ok but when I try
>> to use it in the final linking I get weird errors like:
>> rpc/gimbalnop/server/o-optimize/TtRpcNopCmdSvr.o: In function `MMUon':
>> /usr/local/packages/rtos/rtems/4.9/4.9.0/rtems-4.9.0-mvme5500-build.110708.00/powerpc-rtems4.9/c/mvme5500/lib/libbsp/powerpc/mvme5500/../../../../../../../../rtems-4.9.0/c/src/lib/libbsp/powerpc/mvme5500/start/start.S:139:
>> multiple definition of `MMUon'
>> /opt/rtems-4.9/powerpc-rtems4.9/mvme5500/lib/mvme5500start.o:/usr/local/packages/rtos/rtems/4.9/4.9.0/rtems-4.9.0-mvme5500-build.110708.00/powerpc-rtems4.9/c/mvme5500/lib/libbsp/powerpc/mvme5500/../../../../../../../../rtems-4.9.0/c/src/lib/libbsp/powerpc/mvme5500/start/start.S:139:
>> first defined here
>> rpc/gimbalnop/server/o-optimize/TtRpcNopCmdSvr.o:(.data+0x0): multiple
>> definition of `__dso_handle'
>> /opt/rtems-4.9/lib/gcc/powerpc-rtems4.9/4.3.2/m7400/crtbegin.o:(.data+0x0):
>> first defined here
>> rpc/gimbalnop/server/o-optimize/TtRpcNopCmdSvr.o:(.got2+0x0): multiple
>> definition of `__GOT2_START__'
>> /opt/rtems-4.9/lib/gcc/powerpc-rtems4.9/4.3.2/m7400/ecrti.o:/builddir/build/BUILD/rtems-4.9-powerpc-rtems4.9-gcc-4.3.2/build/gcc/ecrti.S:115:
>> first defined here
>> . etc.
>> This Makefile I'm using is based on a *working* Makefile that builds
>> under linux.
>> After some mods to the original linux Makefile I have something like this:
>> CSRCS = ${CFILES}
>> COBJS_ = $(CSRCS:.c=.o)
>> COBJS = $(COBJS_:%=${ARCH}/%)
>> include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
>> include $(RTEMS_CUSTOM)
>> include $(PROJECT_ROOT)/make/leaf.cfg
>> CPPFLAGS += -I../../.. -I../../../include
>> TARGET = TtRpcNopCmdSvr
>> all: ${TARGET}.o
>> %.o: %.c
>> ${COMPILE.c} ${CPPFLAGS} $<
>> ${TARGET}.o: ${COBJS_}
>> ${LINK.c} -o ${ARCH}/${TARGET}.o -r ${COBJS_}
>> Help appreciated.
>> Thanks,
>> Robert W.
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
