PowerPC BSPs
Till Straumann strauman at slac.stanford.edu
Fri Dec 12 23:46:11 UTC 2008
Leon Pollak wrote:
> On Friday December 12 2008, Till Straumann wrote:
>> Leon Pollak wrote:
>>> Hello, all.
>>> A simple questions to who knows the answer...:-)
>>> All PPC BSPs contain in all interrupt vectors processing the following:
>>> before executing the RFI instruction they restore the MSR value back from
>>> the saved SRR1 value.
>>> Why?
>>> The PPC manual states that this is done by the CPU in the RFI
>>> instruction.
>>> What do I miss?
>>> Thanks.
>> There are various flavors of that stuff - could you please
>> quote the lines and the file you're looking at?
>> Till
> With pleasure. In rtems 4.8.0:
> BSP gen5200/vectors.S, lines about 183;
> BSP mpc8260ads/vectors.S, lines about 125;
> 	file irq_asm.S lines about 281 & 353;
> BSP psim/irq_asm.S, lines about 287 & 338;
> BSP mbx8xx/vectors.S, lines about 131;
> 	file irq_asm.S, lines about 320 & 392.
This fragment of code clears the RI bit in MSR and marks
the beginning of a section of code that is 'non-recoverable'.
An exception handler which sees 'RI' cleared in SRR1 may
thus detect that an exception has occurred somewhere between
clearing RI and the RFI instruction. Here's the scenario
that the code is trying to guard against (psim/irq_asm.S)
     * Disable data and instruction translation. Make path non
recoverable...
    mfmsr   r3
    xori    r3, r3, MSR_RI /* | MSR_IR | MSR_DR */
    mtmsr   r3
    SYNC
     * Restore rfi related settings
    lwz r3, SRR1_FRAME_OFFSET(r1)
    mtsrr1  r3
    lwz r3, SRR0_FRAME_OFFSET(r1)
    mtsrr0  r3
########### if an exception occurs e.g., right here then
########### it is 'non-recoverable' since the contents
########### of SRR0/SRR1 are lost; overwritten with the
########### values of the new exception, e.g.,
########### by 'this' address so the RFI below wouldn't
########### jump where it should.
########### However, by inspecting MSR_RI the exception
########### handler could detect that situation and panic.
    lwz r3, GPR3_OFFSET(r1)
    addi    r1,r1, EXCEPTION_FRAME_END
    SYNC
    rfi
> As the code looks like, it seems that it is simple copy/paste from one source.
Yes. That's why we have overhauled this stuff and are encouraging
new BSP writers to use the code under
libcpu/powerpc/new-exceptions/bspsupport
HTH
-- Till
> Thanks.
