[SOLVED] Re: Problems with Ada hello world examples
Dirk Heinrichs dirk.heinrichs at online.de
Mon Dec 22 07:32:59 UTC 2008
Am Sonntag, 21. Dezember 2008 21:20:16 schrieb Dirk Heinrichs:
> after building rtems 4.9.1 with Ada support, I tried the two "Hello World"
> examples for Ada. While the simple one works fine on real hardware, the 2.5
> seconds delay is much longer in bochs. Any idea how to fix this?
> The tasking example fails on real hardware as well as in bochs with the
> following message:
I forgot to apply the gcc-ada patch when building the toolchain.
However, the hello world examples are not able to cleanly reboot bochs, while
the cpuuse example does it w/o problems.
Bye...
	Dirk
Type: application/pgp-signature
Desc: This is a digitally signed message part.
URL: <http://lists.rtems.org/pipermail/users/attachments/20081222/2c8fe8de/attachment-0001.bin>
