MMC card with spi-sd-card.c
Sebastian Huber
Tue Dec 23 08:15:34 UTC 2008
Sebastian Huber wrote:
> Gene Smith wrote:
>> I have been trying to use an MMC with the "spi/sd" drivers in RTEMS. I
>> worked until it tries to send two commands in a loop waiting for idle
>> conditon in an init routine:
>> rv = sd_card_send_command( e, SD_CARD_CMD_APP_CMD, 0);
>> CLEANUP_RVSC( rv, sc, sd_card_driver_init_cleanup, "Send:
>> SD_CARD_CMD_APP_CMD");
>> rv = sd_card_send_command( e, SD_CARD_ACMD_SD_SEND_OP_COND, 0);
>> SD_CARD_ACMD_SD_SEND_OP_COND");
> These commands set the SD Card into SPI mode.
Oh, I guess I misunderstood you. You want to use a MMC in SPI mode? There are
several ways to switch from MMC mode to SPI mode. This one worked for all
cards I worked with. We may use the alternatives if one approach fails.
Sebastian Huber, Embedded Brains GmbH
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
PGP : Public key available on request
