MMC card with spi-sd-card.c [adding syslog()]
Gene Smith
gds at chartertn.net
Tue Dec 23 22:30:49 UTC 2008
To allow syslog() as alternate to print[fk] I did this in
cpukit/include/rtems/status-checks.h:
#ifndef SYSLOG_PRINT
#ifdef RTEMS_STATUS_CHECKS_USE_PRINTK
#define SYSLOG_PRINT( fmt, ...) \
printk( fmt, ##__VA_ARGS__)
#else
#ifdef RTEMS_STATUS_CHECKS_USE_SYSLOG /*<-define before
status-checks.h includes*/
syslog(LOG_USER|LOG_INFO, fmt, ##__VA_ARGS__)
#else /* default to printf */
printf( fmt, ##__VA_ARGS__)
#endif
#endif /* RTEMS_STATUS_CHECKS_USE_PRINTK */
#endif /* SYSLOG_PRINT */
Before initializing spi with call to bsp_register_spi() in Init() I do:
#include <syslog.h>
#include <rtems/libi2c.h>
#include <rtems/libio.h>
#include <rtems/diskdevs.h>
#include <libchip/spi-sd-card.h>
openlog("[MMC]", LOG_CONS, LOG_USER);
bsp_register_spi();
Finally, to get udp/ip for syslog() to send in spi/i2c code, I had to
temporarily disable locking in cpukit/libi2c/libic2.c:
#if 0
#define LOCK(m) assert(!rtems_semaphore_obtain((m), RTEMS_WAIT,
RTEMS_NO_TIMEOUT))
#define UNLOCK(m) rtems_semaphore_release((m))
#else
#define LOCK(m)
#define UNLOCK(m)
#endif
Not sure why this is needed??
-gene
