ARM946E-S supported by RTEMS?
Wed Feb 20 21:41:46 UTC 2008
Smith, Gene SEA wrote:
> I am looking at the possibility of using RTEMS on a ARM946E-S based
> system. This is a SoC embedded core described here:
> http://www.arm.com/products/CPUs/core_selector.html and here
> http://www.arm.com/products/CPUs/ARM946E-S.html
> There are RPMs for ARM and various BSPs in RTEMS.
> Are the RPMs appropriate for this ARM variant?
They should be since I see this in gcc:
ARM_CORE("arm9tdmi",      arm9tdmi,     4T,    FL_LDSCHED, fastmul)
ARM_CORE("arm920",        arm920,       4T,    FL_LDSCHED, fastmul)
ARM_CORE("arm920t",       arm920t,      4T,    FL_LDSCHED, fastmul)
ARM_CORE("arm922t",       arm922t,      4T,    FL_LDSCHED, fastmul)
ARM_CORE("arm940t",       arm940t,      4T,    FL_LDSCHED, fastmul)
I take that to mean that the 920 is the same as the 940
to gcc and we already have support for 3 920 based BSPs.
> Which ARM BSP (if any) would make the best starting point?
Probably one of the ARM920 ones if I had to guess.
Most of the work will be in device drivers.
We talk about first in CPU family, first with CPU model,
etc.  I think this is logically another board since the CPU
core appears to be supported.
If you need help, that's what I am here for.  I could lend
you a hand to get the ARM working. :-D
--joel
> Thanks,
> -gene
> rtems-users mailing list
> rtems-users at rtems.com
