clock_nanosleep
Moro, Pierre PIERRE.MORO at astrium.eads.net
Mon Feb 25 16:33:19 UTC 2008
Hello everyone,
I'm trying to build some application for a LEON3 proc.
this application uses clock_nanosleep which seems to be part of a
real-time extension of posix and this function is not found while
compiling for leon3 target ( I use the rtems-4.7.99.2 tar given by
gaisler on their website for compiling my project).
Does anyone have any idea if
a) I'm doing something bad and I should find this function
b) or if this is not (yet?) implemented.
In the latter case, how long do you think it would take to implement it
? knowing that I'm just starting with rtems.
thx
Pierre
Pierre Moro, ASTRIUM ST
Tel: +33 (0)1 39 06 72 64      Fax: +33 (0)1 39 06 27 97
Site: LES MUREAUX BD: 19 Floor: 1 Room: 141
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l’utiliser, ni en divulguer le contenu à quiconque. Merci d’en avertir immédiatement l’expéditeur et d'effacer ce courriel de votre système. Astrium décline toute responsabilité en cas de corruption par virus, d’altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Astrium disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Astrium SAS (393 341 516 RCS Paris) – Capital: 16.587.728 EUR – Siège social: 6 rue Laurent Pichat, 75016 Paris, France
URL: <http://lists.rtems.org/pipermail/users/attachments/20080225/b4bfbdc8/attachment.html>
