clock_nanosleep
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Feb 25 16:41:09 UTC 2008
Moro, Pierre wrote:
> Hello everyone,
> I'm trying to build some application for a LEON3 proc.
> this application uses clock_nanosleep which seems to be part of a
> real-time extension of posix and this function is not found while
> compiling for leon3 target ( I use the rtems-4.7.99.2 tar given by
> gaisler on their website for compiling my project).
> Does anyone have any idea if
> a) I'm doing something bad and I should find this function
> b) or if this is not (yet?) implemented.
It is in the not implemented category.
> In the latter case, how long do you think it would take to implement
> it ? knowing that I'm just starting with rtems.
Are you just trying to delay? Are you really trying to send a POSIX
signal? Right now, the only POSIX clock that works is
the one that would be used with nanosleep() or usleep().
It shouldn't be hard to implement based upon what I read
in the opengroup.org specification if all you want is CLOCK_REALTIME.
If you want me to put together an estimate for you of what
it would take for me to implement it for you, I would be
happy to do that after a bit of discussion on what CLOCK_XXX
values you wanted to support. Remember there are at least
these CLOCKS:
+ CLOCK_REALTIME
+ CLOCK_MONOTONIC
+ CLOCK_PROCESS_CPUTIME
+ CLOCK_THREAD_CPUTIME
So I would want to make sure your real requirement was met.
--joel
> thx
> Pierre
> Pierre Moro, ASTRIUM ST
> Tel: +33 (0)1 39 06 72 64 Fax: +33 (0)1 39 06 27 97
> Site:* LES MUREAUX* BD: *19* Floor: *1* Room: *141*
> Ce courriel (incluant ses éventuelles pièces jointes) peut contenir
> des informations confidentielles et/ou protégées ou dont la diffusion
> est restreinte. Si vous avez reçu ce courriel par erreur, vous ne
> devez ni le copier, ni l’utiliser, ni en divulguer le contenu à
> quiconque. Merci d’en avertir immédiatement l’expéditeur et d'effacer
> ce courriel de votre système. Astrium décline toute responsabilité en
> cas de corruption par virus, d’altération ou de falsification de ce
> courriel lors de sa transmission par voie électronique.
> This email (including any attachments) may contain confidential and/or
> privileged information or information otherwise protected from
> disclosure. If you are not the intended recipient, please notify the
> sender immediately, do not copy this message or any attachments and do
> not use it for any purpose or disclose its content to any person, but
> delete this message and any attachments from your system. Astrium
> disclaims any and all liability if this email transmission was virus
> corrupted, altered or falsified.
> Astrium SAS (393 341 516 RCS Paris) – Capital: 16.587.728 EUR – Siège
> social: 6 rue Laurent Pichat, 75016 Paris, France
