Can't Build New Device Driver
Sebastian Huber Sebastian.Huber at embedded-brains.de
Fri Feb 29 17:17:23 UTC 2008
Hi,
I struggle with the BSP development currently too. A "bootstrap -p" in
the top level source directory may fix your problem. It was helpful to
add RTEMS_AMPOLISH3 to the configure.ac since this adds a rule to update
the preinstall.am file if you have enabled the maintainer mode. I also
added "BUILT_SOURCES = preinstall" to the Makefile.am as a workaround to
enforce a preinstall during "make all" in subdirectories.
Ciao,
    Sebastian
Robert S. Grimes wrote:
> make[8]: Entering directory
> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp
> /powerpc/virtex'
> make[8]: *** No rule to make target `preinstall'.  Stop.
> make[8]: Leaving directory
> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp/
> powerpc/virtex'
> make[7]: *** [preinstall-recursive] Error 1
> make[7]: Leaving directory
> powerpc'
> I don't have any idea what the error message means, other than the
> obvious!  Attached are my Makefile.am and the generated Makefile.in for
> your reference.
> Thanks,
> -Bob
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Sebastian Huber           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-6
Fax  : +49-89-18 90 80 79-9
email: Sebastian.Huber at embedded-brains.de
PGP public key available on request
