Can't Build New Device Driver
Robert S. Grimes
rsg at alum.mit.edu
Fri Feb 29 16:52:15 UTC 2008
Oops! I forgot the attachments!
Also, when I ran the bootstrap command, I had a few warnings:
$ ../../../../../../bootstrap
/usr/share/aclocal/cppunit.m4:4: warning: underquoted definition of
AM_PATH_CPPUNIT
/usr/share/aclocal/cppunit.m4:4: run info '(automake)Extending aclocal'
/usr/share/aclocal/cppunit.m4:4: or see
http://sources.redhat.com/automake/automake.html#Extending-aclocal
I don't know if that is significant or not...
Thanks,
-Bob
Robert S. Grimes wrote:
> Hi all,
> How does one develop a new device driver for RTEMS?
> I am trying to develop the low-level driver for SPI support on the
> powerpc/virtex BSP, to support the new libi2c developments Thomas has
> been doing. I'm starting with the RTEMS-4.8.0 release, and trying to
> add the new stuff necessary. With Thomas' help, I've kind of
> determined the code I need to write, but I can't seem to get the
> automake/configure/bootstrap stuff to work.
> I started by configuring, building, installing, and testing
> rtems-4.8.0, using the usual procedure. Then, I copied and modified
> the source code from Thomas' SPI driver in libbsp/powerpc/gen83xx.
> Now I am trying to build it. I've tried to modify the
> virtex/Makefile.am file, but I'm not sure what to do next. I tried
> the following:
> 1. From source tree, in libbsp/powerpc/virtex, I ran bootstrap, like this
> 2. Then, from the build directory, I configured with this command:
> ../rtems-4.8.0/configure --enable-rtems-debug --target=powerpc-rtems \
> --enable-posix --prefix=/usr/rtems/4.8 --enable-networking
> --enable-cxx \
> --enable-rtemsbsp="virtex" --enable-maintainer-mode
> 3. Now, I try to build it, but it breaks. Here is the relevant (I
> think) output from make:
> make[7]: Entering directory
> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp
> /powerpc'
> Making preinstall in virtex
> make[8]: Entering directory
> /powerpc/virtex'
> make[8]: *** No rule to make target `preinstall'. Stop.
> make[8]: Leaving directory
> `/cygdrive/c/Home/ll/etill/rtems/rtems-4.8.0/tools/b-rtems/powerpc-rtems/c/virtex/lib/libbsp/
> powerpc/virtex'
> make[7]: *** [preinstall-recursive] Error 1
> make[7]: Leaving directory
> powerpc'
> I don't have any idea what the error message means, other than the
> obvious! Attached are my Makefile.am and the generated Makefile.in
> for your reference.
> Thanks,
> -Bob
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20080229/41826c83/attachment.ksh>
URL: <http://lists.rtems.org/pipermail/users/attachments/20080229/41826c83/attachment-0001.ksh>
