Correction to the "Ethernet problem"
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Mon Feb 4 19:16:10 UTC 2008
Leon,
Leon Pollak schrieb:
>> Apart from this hint: maybe you can check/eliminate part of the
>> communication path, by directly connecting the PC and the RTEMS system
>> using a TP crossover cable.
> I think this was the most productive idea..:)
> To rework the cables was the problem, but I connected my PC and the box via
> the old 10BaseT HUB and, meanwhile, I am not able to reproduce the problem -
> nothing is lost!
When changing from 100Base-T Switch to a 10MBit Hub, you change several
things:
- The bit rate is slower
- All connections work in half-duplex instead of full duplex
- This also means you MIGHT get collisions (which is implossible, I
think, in full duplex)
- The Hub is a really dumb "repeater", which multiplies a bitstream
coming in to all ports in realtime
- A switch learns and forgets:
It learns, which MAC addresses are available at which port (which source
MAC addresses come from a certain port), and directs any packet only to
the port which corresponds to the destination MAC address. So, before it
can route a packet to your system, your system must have sent a packet
with its own MAC address in the source MAC address field. Only then the
switch knows where it is connected.
And the switch forgets: When it has not received a certain MAC address
for a while (about 15 minutes, I guess), then it erases the proper MAC
address from its routing table.
Can you check, wheter the packet loss only occurs after about 15 minutes
of non-traffic with your system?
In that case it would be worth to put in a different (higher-quality)
switch, which does the learning faster. Actually I never herad about a
switch learning too slow, but ethernet and its protocols rely on the
fact, that packet may get lost, so the effect would not be obvious in
most cases.
wkr,
Thomas.
> So, aren't these the PHYs?
> Many thanks to both of you for your help.
embedded brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
Tel. : +49-89-18 90 80 79-2
Fax : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
