MinGW useage (Re: RTEMS 4.8.0 Available)
Gene Smith
gds at chartertn.net
Sun Feb 24 00:37:01 UTC 2008
Smith, Gene SEA wrote, On 02/22/2008 10:17 AM:
> I failed to prefix the "make all" with "sh" which got rid of the popup
> errors.
Well, actually "sh" did not matter. This error just does not now occur.
> However, still evenutally fails running the "compile" wrapper:
Not sure why this wrapper is invoked since I think current gcc supports
both -c and -o together...?
Anyhow, this still fails in minGW for bsp csb337 but OK for csb336. Both
are ARM940T.
Tried the build using Fedora 8 with rtems-4.8.0 RPMs and csb337 builds
with no errors there. Suspect csb336 OK too but haven't tried it.
In f8, did notice something I am curious about. I do the "make all" in
home. Then I do "sudo make install" and it fails at some point doing
arm-rtem4.8-ranlib. However if I do su then make install it runs to
completion with no errors. Why would sudo not work at this point? Saw
same thing with rtems-4.7.
-gene
