MinGW useage (Re: RTEMS 4.8.0 Available)
Ralf Corsepius ralf.corsepius at rtems.org
Mon Feb 25 14:15:41 UTC 2008
On Sat, 2008-02-23 at 19:37 -0500, Gene Smith wrote:
> In f8, did notice something I am curious about. I do the "make all" in
> home. Then I do "sudo make install" and it fails at some point doing
> arm-rtem4.8-ranlib. However if I do su then make install it runs to
> completion with no errors. Why would sudo not work at this point? Saw
> same thing with rtems-4.7.
PATH?
The RTEMS rpms install their tools to /opt/rtems-<version>/bin, which
isn't in root's PATH.
Ralf
