rtems_event_send problem
Ray rayx.cn at gmail.com
Wed Feb 27 15:42:06 UTC 2008
Hi, 朱旭峰
测试文件对应的Makefile.am
MANAGERS = .....
这一行加上event
如果不清楚用什么就干脆 MANAGERS = all
然后bootstrap,再重新编译。
Thanks & Best Regards!
Ray, rayx.cn at gmail.com
2008-02-27
----- Receiving the following content -----
Receiver:  rtems-users
Time: 2008-02-26, 21:47:22
Subject: rtems_event_send problem
>hi:
>        when i test netdemo ,i found that the routine call the function
>rtems_event_send function in the Start function.
>I got the content of rtems_event_send as following:
>    rtems_status_code rtems_event_send(
>  Objects_Id         id,
>  rtems_event_set event_in
>  _Internal_error_Occurred(
>    INTERNAL_ERROR_RTEMS_API,
>    FALSE,
>    RTEMS_NOT_CONFIGURED
>  return RTEMS_NOT_CONFIGURED;
>             this function is found in file c/src/optman/rtems/no-event.c,
>but i found another rtems_event_send function in file
>cpukit/rtems/src/eventsend.c。
>             So, how to configure the application can make it right?
>              Thanks a lot
>_____________________ next part ______________________
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
