rtems_event_send problem
朱旭峰
fall4ufeng at gmail.com
Tue Feb 26 13:47:22 UTC 2008
hi:
when i test netdemo ,i found that the routine call the function
rtems_event_send function in the Start function.
I got the content of rtems_event_send as following:
rtems_status_code rtems_event_send(
Objects_Id id,
rtems_event_set event_in
_Internal_error_Occurred(
INTERNAL_ERROR_RTEMS_API,
FALSE,
RTEMS_NOT_CONFIGURED
return RTEMS_NOT_CONFIGURED;
this function is found in file c/src/optman/rtems/no-event.c,
but i found another rtems_event_send function in file
cpukit/rtems/src/eventsend.c。
So, how to configure the application can make it right?
Thanks a lot
URL: <http://lists.rtems.org/pipermail/users/attachments/20080226/2914beb4/attachment.html>
