Help regarding linkcmds file
Rahman, Md Sazzadur sazzad at ou.edu
Thu Jan 10 00:30:27 UTC 2008
Hello,
I have ported SCTP(Stream Control Transmission Protocol) in RTEMS from FreeBSD. This is a transport layer protocol and resides with TCP/UDP networking codes in kernel. I have tested it in rtems4.7 and rtems-20011210 in pc386 BSP and it worked well.
However, I need to test it in mpc8260ads BSP, ppc CPU family in rtems-20011210. But  I encountered the following errors by the linker when compiling the SCTP application Makefile:
ld: address 0x10bc20 of o-optimize/sctpApp.exe section .text is not within region ram
ld: section .data [00019004 -> 00020b8b] overlaps section .text [00010000 -> 0010bc1f]
collect2: ld returned 1 exit status
make[2]: *** [o-optimize/sctpApp.exe] Error 1
I guess this is due to the increased size of libnetworking library for ported SCTP. I have found that linkcmds file is responsible for these size specifications but I am not sure how I should modify this linkcmds file to resolve this issue. I have attached linkcmds file and the specification of the board herewith this mail.
I would appreciate any suggestion in this regard.
Please let me know if you have any questions.
Best Regards,
Md Sazzadur Rahman
Graduate Student,
School of Computer Science,
University of Oklahoma,
Norman, Oklahoma, USA
URL: <http://lists.rtems.org/pipermail/users/attachments/20080109/2b48f53d/attachment.html>
Desc: linkcmds
URL: <http://lists.rtems.org/pipermail/users/attachments/20080109/2b48f53d/attachment.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20080109/2b48f53d/attachment.txt>
