Help regarding linkcmds file
Ray rayx.cn at gmail.com
Thu Jan 10 12:47:39 UTC 2008
Hi, Rahman, Md Sazzadur
Your image .text size is above 1M. So you can not put your .text in 0x10000 which is RAM section (only 1M)
I think you got a big SDRAM, why not trying to put text(.text 0x40010000) and data in SDRAM for debug perpurse.
Thanks & Best Regards!
Ray, rayx.cn at gmail.com
2008-01-10
----- Receiving the following content -----
Receiver:  rtems-users at rtems.com
Time: 2008-01-10, 08:30:27
Subject: Help regarding linkcmds file
The attachments of the original message is as following:
linkcmds
README.txt
>Hello,
>I have ported SCTP(Stream Control Transmission Protocol) in RTEMS from FreeBSD. This is a transport layer protocol and resides with TCP/UDP networking codes in kernel. I have tested it in rtems4.7 and rtems-20011210 in pc386 BSP and it worked well.
>However, I need to test it in mpc8260ads BSP, ppc CPU family in rtems-20011210. But  I encountered the following errors by the linker when compiling the SCTP application Makefile:
>ld: address 0x10bc20 of o-optimize/sctpApp.exe section .text is not within region ram
>ld: section .data [00019004 -> 00020b8b] overlaps section .text [00010000 -> 0010bc1f]
>collect2: ld returned 1 exit status
>make[2]: *** [o-optimize/sctpApp.exe] Error 1
>I guess this is due to the increased size of libnetworking library for ported SCTP. I have found that linkcmds file is responsible for these size specifications but I am not sure how I should modify this linkcmds file to resolve this issue. I have attached linkcmds file and the specification of the board herewith this mail.
>I would appreciate any suggestion in this regard.
>Please let me know if you have any questions.
>Best Regards,
>Md Sazzadur Rahman
>Graduate Student,
>School of Computer Science,
>University of Oklahoma,
>Norman, Oklahoma, USA
>_____________________ next part ______________________
>_______________________________________________
>rtems-users mailing list
>http://rtems.rtems.org/mailman/listinfo/rtems-users
