Problem building gcc 4.3.1 cross-compiler with ada
Dirk Heinrichs dirk.heinrichs at online.de
Sun Jul 13 07:23:37 UTC 2008
Hi,
I followed the instructions for building an Ada enabled cross compiler in the
wiki, using binutils 2.18, gcc 4.3.1 and newlib 1.16.0, with all the latest
patches from SOURCES directory applied. Everything went smoothely
until "Build non-multilib C and Ada Cross-Compiler", which failed with the
following error:
/gentoo/build/build-gcc-rtems-ada/./gcc/xgcc -B/gentoo/build/build-gcc-rtems-ada/./gcc/ -nostdinc -B/gentoo/build/build-gcc-rtems-ada/i386-rtems/newlib/ -isystem /gentoo/build/build-gcc-rtems-ada/i386-rtems/newlib/targ-include -isystem /gentoo/build/gcc-4.3.1/newlib/libc/include -B/opt/i386-rtems/bin/ -B/opt/i386-rtems/lib/ -isystem /opt/i386-rtems/include -isystem /opt/i386-rtems/sys-include -c -g -O2      -W -Wall -gnatpg
a-numaux.ads -o a-numaux.o
a-numaux.ads:48:21: package "Ada.Numerics.Aux" does not allow a body
a-numaux.ads:48:21: remove incorrect body in file "a-numaux.adb"
make[4]: *** [a-numaux.o] Fehler 1
make[4]: Leaving directory `/gentoo/build/build-gcc-rtems-ada/gcc/ada/rts'
make[3]: *** [gnatlib] Fehler 2
make[3]: Leaving directory `/gentoo/build/build-gcc-rtems-ada/gcc/ada'
When I look at it, I don't even find a file a-numaux.adb.
Any idea what could be the problem and how to solve it?
Thanks...
	Dirk
Type: application/pgp-signature
Desc: This is a digitally signed message part.
URL: <http://lists.rtems.org/pipermail/users/attachments/20080713/f21980b1/attachment.bin>
