RES: Some notes on the C User's Guide
Fabrício de Novaes Kucinskis fabricio at dea.inpe.br
Fri Jul 11 18:17:47 UTC 2008
Joel,
I checked, and you fixed it all.
Thanks,
Fabrício.
-----Mensagem original-----
De: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Enviada em: sexta-feira, 11 de julho de 2008 13:46
Para: Fabrício de Novaes Kucinskis
Cc: 'RTEMS - Mailing List'
Assunto: Re: Some notes on the C User's Guide
Thanks.
Attached is a diff to the user's manual as found in CVS. I grep'ed for
"invalid task name" and found other occurrences of it and fixed those
also.
Can you review the diff and see if it does indeed fix all the mistakes
you spotted? Please let me know if I missed any or if it is OK.
Once it is OK, I will apply the diff (or something close) to all
active branches.
--joel
Fabrício de Novaes Kucinskis wrote:
> Hello,
> I have compiled some notes on errors or possible errors in the C
> User’s Guide. Some are relevant, some are not. Maybe they can be fixed
> on time to the 4.9 release. The items and page numbers refers to the
> 4.8.0 version of the guide. Follow the list:
> * Page 46, item 5.4.8, task_is_suspended: when a task is NOT
> suspended, the directive returns RTEMS_ALREADY_SUSPENDED? Is it correct?
> * Page 68, item 7.4.1, clock_set: there is no
> RTEMS_INVALID_TIME_OF_DAY macro. Instead, it is returned
> RTEMS_INVALID_CLOCK.
> * Page 74, item 8.2.3, Timer Server: typo: "it would be saVe to
> perform" - correct would be "saFe".
> * Page 131, item 13.4.1, Partition Create: RTEMS_INVALID_NAME denotes
> an invalid “PARTITION name”, or an invalid “RTEMS name”, not an
> invalid "task name”, as in the guide.
> * Page 131, item 13.4.1, "Description": wrong: "Each allocated buffer
> is to be of 'buffer_length' in bytes". The correct would be 'buffer_size'.
> * Page 131, item 13.4.1, Partition Create: ** already reported in
> bugzila: PR1263 **
> * Page 141, item 14.4.1, Region Create: RTEMS_INVALID_NAME denotes an
> invalid “REGION name”, or an invalid “RTEMS name”, not an invalid
> "task" name, as in the guide.
> * Page 141, item 14.4.1, Region Create: my experience using an ERC32
> BSP tells that the page size has to be "a multiple of four greater
> than or equal EIGHT", not “>= 4”, as in the guide. If I try to create
> a region with page_size = 4, I got a RTEMS_INVALID_SIZE error. Maybe
> this is the same problem reported in PR1263?
> I hope this helps. Best regards,
> Fabrício de Novaes Kucinskis - DEA / INPE
> Grupo de Supervisão de Bordo - SUBORD
> Divisão de Eletrônica Aeroespacial
> Instituto Nacional de Pesquisas Espaciais
