Problem installing RTEMS 4.8 tools on Suse 11.0
Roger Beseke roger at cielosolutions.net
Sat Jul 19 20:01:15 UTC 2008
Hi,
    I am trying to install RTEMS 4.8 in an effort to evaluate the tool.  I am
running OpenSuse 11.0.  I have followed the directions on the web.  When I
run the command yum search rtems, I get the following error:
 linux-bx4b:/opt # yum search rtems
Loaded plugins: basearchonly
opensuse                  100% |=========================|  951 B    00:00
primary.xml.gz            100% |=========================|  11 MB    00:33
opensuse  : ################################################## 24580/24580
http://www.rtems.org/ftp/pub/rtems/linux/4.8/suse/11.0/i386/repodata/repomd.xml:
[Errno 14] HTTP Error 404: Not Found
Trying other mirror.
http://www.rtems.info/ftp/pub/rtems/linux/4.8/suse/11.0/i386/repodata/repomd.xml:
Error: Cannot retrieve repository metadata (repomd.xml) for repository:
rtems-4.8. Please verify its path and try again
  I have noticed that the actual repository has a label of i586 as opposed to
i386.  I am guessing this is the problem.  Being a newby to this, I would
appreciate any thoughts that someone might have on correcting this problem
Thanks in advance
Roger
