Problem installing RTEMS 4.8 tools on Suse 11.0
Ralf Corsepius ralf.corsepius at rtems.org
Thu Jul 24 07:29:40 UTC 2008
On Sat, 2008-07-19 at 13:01 -0700, Roger Beseke wrote:
> Hi,
>     I am trying to install RTEMS 4.8 in an effort to evaluate the tool.  I am
> running OpenSuse 11.0.  I have followed the directions on the web.  When I
> run the command yum search rtems, I get the following error:
>  linux-bx4b:/opt # yum search rtems
> Loaded plugins: basearchonly
> opensuse                  100% |=========================|  951 B    00:00
> primary.xml.gz            100% |=========================|  11 MB    00:33
> opensuse  : ################################################## 24580/24580
> http://www.rtems.org/ftp/pub/rtems/linux/4.8/suse/11.0/i386/repodata/repomd.xml:
> [Errno 14] HTTP Error 404: Not Found
> Trying other mirror.
> http://www.rtems.info/ftp/pub/rtems/linux/4.8/suse/11.0/i386/repodata/repomd.xml:
> Error: Cannot retrieve repository metadata (repomd.xml) for repository:
> rtems-4.8. Please verify its path and try again
>   I have noticed that the actual repository has a label of i586 as opposed to
> i386. I am guessing this is the problem.
Correct.
The error message indicates your yum's $basearch
(cf. /etc/yum.repos.d/rtems-4.8.repo) not to match the expectations on
the server.
>   Being a newby to this, I would
> appreciate any thoughts that someone might have on correcting this problem
Well, the key to resolve this issue would be to know why $basearch is
being set to i386 on your system.
Ralf
