RES: pc686 bsp for executables bigger than 1.44Mbytes
Wendell Pereira da Silva
wendell.silva at compsisnet.com.br
Wed Jul 30 22:12:22 UTC 2008
Is it possible to use a USB flash memory?
If yes, is grub a good solution?
Wendell.
-----Mensagem original-----
De: rtems-users-bounces at rtems.org [mailto:rtems-users-bounces at rtems.org]
Em nome de Chris Johns
Enviada em: quarta-feira, 30 de julho de 2008 19:04
Para: John Pickwick
Cc: rtems-users at rtems.org
Assunto: Re: pc686 bsp for executables bigger than 1.44Mbytes
John Pickwick wrote:
> Hi to all,
> as a prototyping platform I use a simple celeron pc with the pc686 bsp
(with
> rtems4.8.0) but my executable is getting bigger and bigger :=( The pc
is
> under windows and I used to boot from a floppy disk using the grub
package
> but I can no longer do it since my executable reached the 1.44MB limit
> what are the other simple solutions to run my application (I don't
have any
> filesystem installed in my application) ?
I am using an old PC and the pc386 BSP to test file system code. My
solution
is to use etherboot. I copied it onto a floppy disk and boot from it.
Etherboot performs a DHCP request which has the file to download in it.
The
etherboot image can download and boot the RTEMS ELF file.
The etherboot image I use can be found here:
http://www.rtems.org/ftp/pub/rtems/people/chrisj/pc386/etherboot/
Regards
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
