pc686 bsp for executables bigger than 1.44Mbytes
Wed Jul 30 23:57:31 UTC 2008
John Pickwick wrote:
> Well, this PC is not connected to a network. I was more interested in
> something like reading the executable from a hard disk or an USB memory as
> Wendell suggested. I'm not a grub expert, do you think I can indicate the
> path of an executable located on a USB device ?
Why not use qemu and not use real hardware ? The Wiki has details on using
qemu. I do a great deal of development for RTEMS using qemu.
I only moved to a real PC so I could make sure the changes to RTEMS where
tested on real hardware and with a real ATA (IDE) hard disk.
> Otherwise what would be the main steps to access the PC hard disk from a
> "floppy-booted" rtems executable ? I have a FAT32 or NTFS format on it. I
> guess I must declare some kind of ATA driver ?
RTEMS does support FAT but not NTFS. You could look at grub boot RTEMS from
one of those disks. I have not done it but I assume it could.
You could also boot to DOS (or FreeDOS) from a floppy and have x.exe boot
RTEMS. See http://www.rtems.org/wiki/index.php/Pc386.
To show how to get RTEMS to access a disk take a look at my test application.
It shows how to handle the various file systems and mounts. It should make a
suitable example. I use the shell and a shell init script to mount the various
devices.
http://www.rtems.org/ftp/pub/rtems/people/chrisj/file-system/filesystem-test-20080729.tar.gz
This example does expect a $(EXEEXT) makefile change for RTEMS that is
currently not applied.
Regards
