POSIX FIFO/pipe
Wei Shen
cquark at gmail.com
Thu Jul 31 11:16:18 UTC 2008
Hi Joel,
I wrote several mails to you but got no reply for quite a few days. I guess
there must be sth. wrong. Maybe, my mails were recognized as spams, so I try
adding rtems-users...
On 7/26/08, Wei Shen <cquark at gmail.com> wrote:
Thanks for the quick reply.
On 7/25/08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> 1. POSIX says when pipe IO can be interrupted by signals. I remember we
>> think it is better to make FIFO/pipe independant of POSIX API.
> What is your blocking mechanism in the pipe code?
> When blocking in RTEMS, you can specify an extra state bit
> STATES_INTERRUPTIBLE_BY_SIGNAL. So you can be blocking
> on a mutex and that particular mutex API implementation may be
> written to set the STATES_INTERRUPTIBLE_BY_SIGNAL bit.
> When a signal occurs, that bit is checked.
I use semaphore and barrier. I just want barrier_wait to be interruptible,
but semaphore not.
I do not quite understand what you mean. I do not find such interfaces in
barrier implementation. Do you mean I just need to set
STATES_INTERRUPTIBLE_BY_SIGNAL before barrier_wait and clear it after; or
barrier need hooking to check the state bit?
> 3. For anonymous pipes, it is easier to implement them as FIFOs with
>> arbitrary names. So what kind of paths is prefered for pipes?
Maybe, sth. like: /tmp/.pipe#id, where id is a 32bit integer?
> BTW, I also found IMFS_memfile_write does not strictly follow POSIX in
>> that, it updates file ATime and MTime, while POSIX requires file write to
>> update MTime and CTime.
> Can you submit a patch and pointer to opengroup.org?
http://www.opengroup.org/onlinepubs/009695399/functions/write.html
"Upon successful completion, where *nbyte* is greater than 0, *write*()
shall mark for update the *st_ctime* and *st_mtime* fields of the file, and
if the file is a regular file, the S_ISUID and S_ISGID bits of the file mode
may be cleared."
(I have not checked the last sentence)
--- imfs.h.new 2008-07-25 14:20:27.000000000 -0700
+++ imfs.h 2008-07-09 23:03:51.000000000 -0700
@@ -196,12 +196,12 @@
_jnode->stat_ctime = (time_t) tv.tv_sec; \
} while (0)
-#define IMFS_mtime_ctime_update( _jnode ) \
+#define IMFS_atime_mtime_update( _jnode ) \
do { \
struct timeval tv; \
gettimeofday( &tv, 0 ); \
_jnode->stat_mtime = (time_t) tv.tv_sec; \
- _jnode->stat_ctime = (time_t) tv.tv_sec; \
+ _jnode->stat_atime = (time_t) tv.tv_sec; \
} while (0)
--- memfile.c.new 2008-07-25 14:19:38.000000000 -0700
+++ memfile.c 2008-07-02 18:37:38.000000000 -0700
@@ -844,7 +844,7 @@
copied += to_copy;
- IMFS_mtime_ctime_update( the_jnode );
+ IMFS_atime_mtime_update( the_jnode );
return copied;
URL: <http://lists.rtems.org/pipermail/users/attachments/20080731/b8a55f90/attachment.html>
