Countdown to 4.9 Branching Point
Wed Jul 9 22:29:53 UTC 2008
Joel Sherrill wrote:
> Hi,
> Ralf has laid the groundwork for 4.10 tools and
> I had want to cut the 4.9 branch this week. RTEMS
> itself looks better than it has at any previous
> branching point.
> At this point, I know of a few outstanding
> development efforts I think are close and wanted
> to make 4.9.
> + Chris - some bdbuf work that greatly improves
>   flash file system performance.
> + Thomas - has mentioned a couple of BSPs on the
>   user's list.  Hint (two weeks :-D).  Are they
>   going to make it?
> How close are these?
I am very close. I have the chains doco in and it has been built overnight.
I am trying to get an ATA test set up with qemu working to run some tests. I
might dig out an old PC to use with a real disk.
> Is there anything else?
I would like to fix up the m68k.h issues we have as a fall out from the mlib
discussion. If this misses I will apply to both branches.
> If you have something you want in, submit it ASAP.
> Otherwise, the branch will be cut by the end
> of this week.
> GSOC work will go into 4.10.
