skyeye 1.2.5 and Various BSPs
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Jul 29 13:30:51 UTC 2008
xu ray wrote:
> Skysye only release source code package. I think just download
> skyeye1.2.5 and configure and make with default option, every thing
> will be fine. There will be a skyeye elf file in the dir.
> however, there are some documents if anyone would interested in more
> details on how to use it.
> http://skyeye.wiki.sourceforge.net/UserManual
> http://www.rtems.org/wiki/index.php/SkyEye
> BTW, qemu seems also achieve lots of progress in support multiple CPU
> in recent release(including arm, cortex, coldfire, Mips support). Did
> anyone try?
This is on the RTEMS wishlist. I haven't seen any progress on this front.
My first goal with simulators is to cover more architectures so we can
do automated testing of RTEMS and tools on at least one BSP per
architecture. The next target on my list to address is arm.
--joel
> 2008/7/29 Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>>
> Joel Sherrill wrote:
> > Hi,
> > This is IMPORTANT so if you can help at all,
> > it is needed. This is an attempt to broaden
> > the automated testing as we finalize a release.
> > I have spent some time over the past few days
> > trying to get scripts together so we could
> > use Skyeye 1.2.5 as an automated test platform
> > for a variety of BSPs. In doing so, I have
> > found a number of problems and need help
> > from a variety of BSP folks.
> > + arm/edb7312 - fine on 4.8, ticker gives SKYEYE
> > error on 4.9
> > + arm/csb336 - locks on both 4.8 and 4.9
> > waiting for clock tick
> > + arm/rtl22xx - fine on 4.8, ticker gives SKYEYE
> > error on 4.9
> > + bfin/eZKit533 - doesn't run on either 4.8 or 4.9.
> > If you have a BSP on Skyeye I didn't mention,
> > please speak up. I would really like a coldfire
> > BSP on a simulator.
> > If you can fix one of the above or have some insight,
> > please speak up. Better if you can fix something.
> Is there any info on setting up SkyEye on fc8 ?
> Regards
> Chris
> rtems-users mailing list
> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
> Thanks & Best Regards!
> Ray, Xu
