Error from ampolish3
Mon Jun 2 16:02:25 UTC 2008
I'm sure you have told us before but what OS and version Neil?
Neil Mayes wrote:
>> -----Original Message-----
>> From: Ralf Corsepius [mailto:ralf.corsepius at rtems.org]
>> Sent: 02 June 2008 16:54
>> To: Neil Mayes
>> Cc: rtems-users at rtems.org
>> Subject: RE: Error from ampolish3
>> On Mon, 2008-06-02 at 15:48 +0100, Neil Mayes wrote:
>>> Hi,
>>> I have (tried to!) added some device drivers to a BSP (ERC32) and
>>> wanted to isolate the IO control to a HW API. So the
>> application would
>>> just need to include the header and all will be well. Once
>> I realised
>>> I needed to regenerate preinstall.am I used bootstrap -p however I
>>> encountered the following error:
>>> Can't do setuid (cannot exec sperl)
>> Not from RTEMS. Nothing in RTEMS is using suid-perl.
>>> Has anyone got an clue where the error is coming from?
>> Seems to me as if you have a permission problem with your
>> source tree or a problem with your perl installation.
> I suspect the perl setup :(
>> Ralf
> Thanks Ralf
> rtems-users mailing list
> rtems-users at rtems.com
