Announcement: C-Code generator from UML state charts
Peter Mueller
peter.o.mueller at gmx.de
Tue Jun 3 17:55:14 UTC 2008
Hello list readers,
I've developed a small tool (called sinelaboreRT) that generates C-
Code from UML state charts. SinelaboreRT is a java based console
application. The UML state charts can be designed with the Cadifra
UML editor. The generation process can be widely adjusted to your needs.
sinelaboreRT was built especially with embedded real-time systems in
mind. Here are some of the main features:
- Generates human readable C-code
- No run-time environment needed
- Fits well in different system designs (foreground/background, RTOS-
based ...)
- No gap between design and code anymore
- Drawing professional quality state-charts using Cadifra UML Editor
- Simple integration in different development environments
- Low cost
If you want to give it a try please visit www.sinelabore.com and take
a look in the manual.
There is a demo version of both tools available.
With best regards,
Peter Mueller
Peter Mueller
info at sinelabore.com
www.sinelabore.com
URL: <http://lists.rtems.org/pipermail/users/attachments/20080603/78d66261/attachment.html>
