Get the output of a program in a file using QEmu
Reng Zeng alan at fiucssa.org
Wed Jun 25 17:11:21 UTC 2008
It does not work as well with '-serial stdio',
btw, I also 'make clean' 'make' my program. And, when I make , it seems do
not have any "USE_COM1_AS_CONSOLE" in it, is that the problem?
i386-rtems4.9-gcc --pipe -B/opt/rtems-4.9/i386-rtems4.9/pc586/lib/ -specs
bsp_specs -qrtems   -g -Wall  -O2 -g -g    -mtune=pentium     -c   -o
o-optimize/init.o init.c
Thanks,
Alan
2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com>:
> Reng Zeng wrote:
>> Hi Joel,
>> Thanks for your tips, I tried it as steps below, it still does not work.
>> 1.  ../rtems/configure USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
>> --target=i386-rtems4.9 --enable-rtemsbsp=pc586 --disable-posix
>> --disable-itron --enable-tests=samples
>> 2. make clean
>> 3. make
>> 4. make install
>> Then I run it my qemu:
>> /usr/bin/qemu -monitor null -nographic -serial file:qemu.log -boot a -m
>> 128 -fda '/home/zengreng/rtems-boot.img' -hda
>> 'fat:/home/zengreng/workspace/rtems_tools/src/generated/'  --no-reboot
>>  Try -serial stdio and see if that works.  Maybe file: doesn't work.  I
> have never used it.
>> The program to run is managed by Makefile I drafted, not automake, I
>> attached it to see whether that is the cause things do not work, shall I add
>> something like "USE_COM1_AS_CONSOLE" into it as well?
>>  There was no program attached but any of the samples should just work
> that way.
>> Thanks again,
>> Alan
>> 2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com <mailto:
>> joel.sherrill at oarcorp.com>>:
>>    Reng Zeng wrote:
>>        Hello,
>>        It do NOT work for me, I add "#define USE_COM1_AS_CONSOLE 1 "
>>        into my init.c, and run qemu by
>>            qemu -nographic -serial file:output.txt -boot a -m 128
>>        -fda myimage.img -hda fat:.
>>    No.  That's not going to work.  You have to configure with that
>>    set on the configure
>>    comment line.
>>    ..../configure ... USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
>>    The BSP_PRESS_KEY_FOR_RESET=0 configures the BSP to not wait for a key
>>    press before resetting.  Just add  --no-reboot to your qemu
>>    command line and
>>    it will "power down" which is exiting. :-D
>>        I did not get anything from output.txt. It run well in graphic
>>        mode, but I want the output from the program.
>>        I would appreciate if you could shed me some light on my mind :)
>>    This is a fragement from the shell script I use.
>>    QEMU="/usr/local/bin/qemu -cpu 486"
>>    runit()
>>     ARGS="-m 8 -boot a -fda ${fd0Image} -hda fat:${hd0Dir} \
>>           -monitor null -nographic -serial stdio --no-reboot"
>>      ${QEMU} ${ARGS} >${logfile} 2>&1 &
>>        Thanks,
>>        Alan
>>        2008/3/21 Jean-Claude Grange <lebauce at free.fr
>>        <mailto:lebauce at free.fr> <mailto:lebauce at free.fr
>>        <mailto:lebauce at free.fr>>>:
>>           Hello,
>>           Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked
>>        just fine.
>>           I'm really interested in your patch, Joel. Are you going to
>>        commit it
>>           soon ? Or would you mind sending your patch to me so that I can
>>           test it.
>>           Thanks
>>           See you
>>           Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
>>           > Jean-Claude Grange wrote:
>>           >> Hello,
>>           >> Thanks for your answer. I'll try that.
>>           >> But I wonder if it's possible to do it without modifying the
>>           >> program ?
>>           > Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
>>           > command line and the console will move to the serial port.
>>           > This is how I run RTEMS and GCC tests in an automated
>>           > fashion.
>>           > I discovered another nice qemu option --no-reboot which
>>           > exits when the simulated PC does a reset.  This means you
>>           > get a single run of the application and then it exits.  I
>>        have
>>           > a pending patch in my tree to make the BSP reset on
>>           > application exit or exception without waiting for a human
>>           > to press a character.  This sped up the gcc test runs
>>           > by a large factor since they have >50K tests.
>>           > --joel
>>           >> José Marinho <zemanel at gmail.com
>>        <mailto:zemanel at gmail.com> <mailto:zemanel at gmail.com
>>        <mailto:zemanel at gmail.com>>> wrote:
>>           >>> you can allways create a file, format it to a specific
>>        fylesystem
>>           >>> and pass
>>           >>> it to qemu as an hard drive, and tell the rtems program
>>        to create
>>           >>> and write
>>           >>> in a file in that hard drive. and then you can mount
>>        that file
>>           >>> with loop
>>           >>> device and access it and get the output file. that's
>>        the approach
>>           >>> that I'de
>>           >>> take. Hope that's usefull to you
>>           >>> José Marinho
>>           >>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr
>>           <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>> wrote:
>>           >>>> Hello,
>>           >>>> I'm sorry if this is a stupid question but I've
>>        searched on the
>>           >>>> mailing
>>           >>>> list and
>>           >>>> didn't find an answer.
>>           >>>> I'm trying to get the output of a RTEMS program (for
>>        example the
>>           >>>> Hello
>>           >>>> from the
>>           >>>> samples testsuite) using QEmu, into a file. I'm using the
>>           >>>> command (on
>>           >>>> Linux) :
>>           >>>> qemu -nographic -serial file:output.txt -boot a -fda
>>        myimage.img
>>           >>>> -hda
>>           >>>> fat:.
>>           >>>> but I don't get anything in the 'output.txt' file. I
>>        also tried -
>>           >>>> serial
>>           >>>> /dev/ttyS* and with the -monitor stdio option but I
>>        still have
>>           >>>> nothing. I
>>           >>>> must
>>           >>>> be doing something wrong.
>>           >>>> I would really appreciate your help.
>>           >>>> Thank you
>>           >>>> _______________________________________________
>>           >>>> rtems-users mailing list
>>           >>>> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
>>        <mailto:rtems-users at rtems.com <mailto:rtems-users at rtems.com>>
>>           >>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>           >>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </img>
>>           > Joel Sherrill, Ph.D.             Director of Research &
>>        Development
>>           > joel.sherrill at OARcorp.com        On-Line Applications
>>        Research
>>           > Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>           >   Support Available             (256) 722-9985
>>    --    Joel Sherrill, Ph.D.             Director of Research &
>> Development
>>    joel.sherrill at OARcorp.com        On-Line Applications Research
> Joel Sherrill, Ph.D.             Director of Research & Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20080625/c18541c2/attachment-0001.html>
