Get the output of a program in a file using QEmu
Daron Chabot
daron.chabot at usask.ca
Wed Jun 25 17:20:43 UTC 2008
What version of Qemu are you using ?
To narrow down the problem, try using one of the sample/test programs
in /opt/rtems-4.9/i386-rtems4.9/pc586/lib/rtems-4.9/tests (eg:
hello.exe).
The command line I use with Qemu 0.9.1 is:
qemu -no-reboot -m 128 -boot n -tftp /opt/rtems/i386-rtems/pc386/lib/
rtems-4.9/tests -bootp /hello.exe -serial stdio
-- dc
On 25-Jun-08, at 11:11 AM, Reng Zeng wrote:
> It does not work as well with '-serial stdio',
> btw, I also 'make clean' 'make' my program. And, when I make , it
> seems do not have any "USE_COM1_AS_CONSOLE" in it, is that the
> problem?
> i386-rtems4.9-gcc --pipe -B/opt/rtems-4.9/i386-rtems4.9/pc586/lib/ -
> specs bsp_specs -qrtems -g -Wall -O2 -g -g -mtune=pentium
> -c -o o-optimize/init.o init.c
> Thanks,
> Alan
> 2008/6/25 Joel Sherrill <joel.sherrill at oarcorp.com>:
> Reng Zeng wrote:
> Hi Joel,
> Thanks for your tips, I tried it as steps below, it still does not
> work.
> 1. ../rtems/configure USE_COM1_AS_CONSOLE=1
> BSP_PRESS_KEY_FOR_RESET=0 --target=i386-rtems4.9 --enable-
> rtemsbsp=pc586 --disable-posix --disable-itron --enable-tests=samples
> 2. make clean
> 3. make
> 4. make install
> Then I run it my qemu:
> /usr/bin/qemu -monitor null -nographic -serial file:qemu.log -boot
> a -m 128 -fda '/home/zengreng/rtems-boot.img' -hda 'fat:/home/
> zengreng/workspace/rtems_tools/src/generated/' --no-reboot
> Try -serial stdio and see if that works. Maybe file: doesn't
> work. I have never used it.
> The program to run is managed by Makefile I drafted, not automake,
> I attached it to see whether that is the cause things do not work,
> shall I add something like "USE_COM1_AS_CONSOLE" into it as well?
> There was no program attached but any of the samples should just work
> that way.
> Thanks again,
> Alan
> <mailto:joel.sherrill at oarcorp.com>>:
> Reng Zeng wrote:
> Hello,
> It do NOT work for me, I add "#define USE_COM1_AS_CONSOLE 1 "
> into my init.c, and run qemu by
> qemu -nographic -serial file:output.txt -boot a -m 128
> -fda myimage.img -hda fat:.
> No. That's not going to work. You have to configure with that
> set on the configure
> comment line.
> ..../configure ... USE_COM1_AS_CONSOLE=1 BSP_PRESS_KEY_FOR_RESET=0
> The BSP_PRESS_KEY_FOR_RESET=0 configures the BSP to not wait for
> a key
> press before resetting. Just add --no-reboot to your qemu
> command line and
> it will "power down" which is exiting. :-D
> I did not get anything from output.txt. It run well in graphic
> mode, but I want the output from the program.
> I would appreciate if you could shed me some light on my
> mind :)
> This is a fragement from the shell script I use.
> QEMU="/usr/local/bin/qemu -cpu 486"
> runit()
> ARGS="-m 8 -boot a -fda ${fd0Image} -hda fat:${hd0Dir} \
> -monitor null -nographic -serial stdio --no-reboot"
> ${QEMU} ${ARGS} >${logfile} 2>&1 &
> Thanks,
> Alan
> 2008/3/21 Jean-Claude Grange <lebauce at free.fr
> <mailto:lebauce at free.fr> <mailto:lebauce at free.fr
> <mailto:lebauce at free.fr>>>:
> Hello,
> Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked
> just fine.
> I'm really interested in your patch, Joel. Are you going to
> commit it
> soon ? Or would you mind sending your patch to me so that
> I can
> test it.
> Thanks
> See you
> Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
> > Jean-Claude Grange wrote:
> >> Hello,
> >> Thanks for your answer. I'll try that.
> >> But I wonder if it's possible to do it without
> modifying the
> >> program ?
> > Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
> > command line and the console will move to the serial port.
> > This is how I run RTEMS and GCC tests in an automated
> > fashion.
> > I discovered another nice qemu option --no-reboot which
> > exits when the simulated PC does a reset. This means you
> > get a single run of the application and then it exits. I
> have
> > a pending patch in my tree to make the BSP reset on
> > application exit or exception without waiting for a human
> > to press a character. This sped up the gcc test runs
> > by a large factor since they have >50K tests.
> > --joel
> >> José Marinho <zemanel at gmail.com
> <mailto:zemanel at gmail.com> <mailto:zemanel at gmail.com
> <mailto:zemanel at gmail.com>>> wrote:
> >>> you can allways create a file, format it to a specific
> fylesystem
> >>> and pass
> >>> it to qemu as an hard drive, and tell the rtems program
> to create
> >>> and write
> >>> in a file in that hard drive. and then you can mount
> that file
> >>> with loop
> >>> device and access it and get the output file. that's
> the approach
> >>> that I'de
> >>> take. Hope that's usefull to you
> >>> José Marinho
> >>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr
> <mailto:lebauce at free.fr <mailto:lebauce at free.fr>>> wrote:
> >>>> Hello,
> >>>> I'm sorry if this is a stupid question but I've
> searched on the
> >>>> mailing
> >>>> list and
> >>>> didn't find an answer.
> >>>> I'm trying to get the output of a RTEMS program (for
> example the
> >>>> Hello
> >>>> from the
> >>>> samples testsuite) using QEmu, into a file. I'm
> using the
> >>>> command (on
> >>>> Linux) :
> >>>> qemu -nographic -serial file:output.txt -boot a -fda
> myimage.img
> >>>> -hda
> >>>> fat:.
> >>>> but I don't get anything in the 'output.txt' file. I
> also tried -
> >>>> serial
> >>>> /dev/ttyS* and with the -monitor stdio option but I
> still have
> >>>> nothing. I
> >>>> must
> >>>> be doing something wrong.
> >>>> I would really appreciate your help.
> >>>> Thank you
> >>>> _______________________________________________
> >>>> rtems-users mailing list
> >>>> rtems-users at rtems.com <mailto:rtems-users at rtems.com>
> <mailto:rtems-users at rtems.com <mailto:rtems-users at rtems.com>>
> >>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> >>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </
> img>
> > Joel Sherrill, Ph.D. Director of Research &
> Development
> > joel.sherrill at OARcorp.com On-Line Applications
> Research
> > Ask me about RTEMS: a free RTOS Huntsville AL 35805
> > Support Available (256) 722-9985
> -- Joel Sherrill, Ph.D. Director of Research &
> Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Joel Sherrill, Ph.D. Director of Research & Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20080625/92615e06/attachment-0001.html>
