netdriver transmit problem
Ray rayx.cn at gmail.com
Sat Mar 1 13:33:27 UTC 2008
Hi, 朱旭峰
You can set break point in your driver. However, some netwok sniffer like ethereal might help if your target is a PC.
Thanks & Best Regards!
Ray, rayx.cn at gmail.com
2008-03-01
----- Receiving the following content -----
Receiver:  rtems-users
Time: 2008-03-01, 19:16:13
Subject: netdriver transmit problem
>Hi, all:
>      When i tested netdemo,the console print "*Can't connect socket:
>Connection timed out*"   after i typed *'t'*.
>      I don't know the source code of transmit and receive routine is right
>or not,
>*so I wonder the information printed by the console is regular* ?
>     I noticed that the driver call the *ether_output* routine when network
>was being initialized.And the ether_output routine called the
>*start routine* to transmit the first packet。
>     *What should i do if i want to know this packet is transmit successful
>or not*?
>     Best regards!
>_____________________ next part ______________________
>_______________________________________________
>rtems-users mailing list
>rtems-users at rtems.com
>http://rtems.rtems.org/mailman/listinfo/rtems-users
