How to build/install libi2c?
Robert S. Grimes rsg at alum.mit.edu
Fri Mar 7 18:03:09 UTC 2008
Thomas Doerfler wrote:
> Robert,
> libi2c is part of the cpukit, so it should be "just there" when you link
> your application with RTEMS.
Hi Thomas,
Be where?  I looked at the libs (find powerpc-rtems -name '*.a') in my
install point, and I couldn't find definitive evidence.
By the way, here is the error I'm getting
Making all in main
make[1]: Entering directory
`/cygdrive/c/Home/ll/etill/development/apps/laser/main'
powerpc-rtems-g++ -B/usr/rtems/4.8/powerpc-rtems/virtex/lib/ -specs
bsp_specs -qrtems   -g -Wall  -g    -mcpu=403 -Dppc405 -Dvirtex
-I../include -I../../include -I../../../common/include -I
../../../common/include/commands -o o-optimize/app.exe
o-optimize/app.o ../../lib/epp/o-optimize/libepp.a
../../../common/src/eppcommon/o-optimize/libeppcommon.a
../../lib/epp/o-optimize/libepp.a(spi-fram-ramtron.o): In function
`spi_fram_ramtron_read':
/cygdrive/c/Home/ll/etill/development/apps/lib/spi/spi-fram-ramtron.c:285:
undefined reference to `rtems_libi2c_ioctl'
`spi_fram_ramtron_write':
/cygdrive/c/Home/ll/etill/development/apps/lib/spi/spi-fram-ramtron.c:133:
/cygdrive/c/Home/ll/etill/development/apps/lib/spi/spi-fram-ramtron.c:186:
collect2: ld returned 1 exit status
Thanks,
-Bob
> wkr,
> Thomas.
> Robert S. Grimes schrieb:
>> Hi all,
>> How do I get libi2c to build?
>> I'm guessing it would normally get built by the BSP, right?  However,
>> I'm trying to develop a driver as part of my application, and the
>> powerpc/virtex BSP doesn't use libi2c.  Is there a special make target?
>> Or a configure option?  Something else?
>> Thanks!
>> -Bob
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
> embedded brains GmbH
> Thomas Doerfler           Obere Lagerstr. 30
> D-82178 Puchheim          Germany
> Tel. : +49-89-18 90 80 79-2
> Fax  : +49-89-18 90 80 79-9
> email: Thomas.Doerfler at embedded-brains.de
> PGP public key available on request
