How to build/install libi2c? - RESOLVED
Robert S. Grimes rsg at alum.mit.edu
Fri Mar 7 23:10:25 UTC 2008
Thomas Doerfler wrote:
> Robert,
> libi2c is part of the cpukit, so it should be "just there" when you link
> your application with RTEMS.
Okay, as usual, you're quite right, Thomas!
The unresolved symbol 'rtems_libi2c_ioctl' is, as you know, from the
newer libi2c.c, not that in 4.8.0.  I started with 4.8.0 by making and
installing, then added the new stuff, then ran make again.  Apparently,
I forgot the 'make install' step!!!  Ouch!
Sorry about the noise...
-Bob
