rtems-users Digest, Vol 18, Issue 16
Matthieu Bucchianeri
mbucchia at gmail.com
Sat Mar 15 22:16:08 UTC 2008
On Sat, Mar 15, 2008 at 10:00 AM, <rtems-users-request at rtems.org> wrote:
> >> + Offer this library as a pre-built RPM. This is the cleanest
> >> solution for GNU/Linux users and is in keeping with the existing
> >> infrastructure. It treats it as a 3rd party package that we
> >> provide pre-compiled and version synchronization is under our
> >> control.
> > This probably *is* the cleanest solution. I will volunteer to package
> > up the required library; this probably only involves putting together an
> > RPM .spec file and submitting the package to a repository.
> Ralf Corsepius hasn't piped up but it would be better if
> it ended up in the RTEMS repository so it could match the
> BSP. Plus Matthieu did have some patches.
This is the simplest solution and given the license of
libnds/libfat/dswifi -- ie: no licence -- it could work. When there is
a major bug fix or feature improvement in one of these libs, we will
need to update the repository.
For sure we can imagine the next version of libnds/libfat/dswifi won't
match the BSP, so this solution also solves this problem.
About the patches, I think we can avoid them by doing tricky things in
the autotools. For example the main problem I have with libnds is that
the assembly file are ending with .s while they are not preprocessed
(should be .S).
> Thanks for offering. Hopefully Ralf won't see any issues
> with offering this as an RPM.
Even if we decide to provide an RPM, we'll have to change the
autotools. An RPM will install the libnds/libfat/dswifi in a
privileged directory (like /opt/rtems-4.9/src ...) and it won't be
writable (the patch can't be applied as-is).
> > -- D.
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
> rtems-users mailing list
> rtems-users at rtems.com
Matthieu ``buckman'' Bucchianeri
VMkernel Networking Team intern
http://www.VMware.com
