Rtems provided by gaisler and modifications ?
Moro, Pierre
PIERRE.MORO at astrium.eads.net
Tue Mar 18 15:49:26 UTC 2008
Hi everyone,
Does someone knows how different is the rtems provided by gaisler for
leon3 boards on their website (4.7.99.2) is really different than the
one that can be obtained via rpms ?
In particular, I have some troubles with the
rtems_bsdnet_initialize_network function that runs forever when loaded
with the simulator tsim-leon3 (I hope that my problem is not due to the
tsim)
But, I can't say more since I have precompiled cpukit and I can't even
put some printf (or printk ? btw, what is printk?) in the differents
functions to see what kind of functions are called.
I've read a few topics on similar problems on this mailing list, and I
already tried to "pack" structures in ip_var.h.
I used the bsp provided by gaisler for leon3.
And now I'm out of ideas ...
Thx in advance
Pierre
Pierre Moro, ASTRIUM ST
Tel: +33 (0)1 39 06 72 64 Fax: +33 (0)1 39 06 27 97
Site: LES MUREAUX BD: 19 Floor: 1 Room: 141
Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des informations confidentielles et/ou protégées ou dont la diffusion est restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni le copier, ni l’utiliser, ni en divulguer le contenu à quiconque. Merci d’en avertir immédiatement l’expéditeur et d'effacer ce courriel de votre système. Astrium décline toute responsabilité en cas de corruption par virus, d’altération ou de falsification de ce courriel lors de sa transmission par voie électronique.
This email (including any attachments) may contain confidential and/or privileged information or information otherwise protected from disclosure. If you are not the intended recipient, please notify the sender immediately, do not copy this message or any attachments and do not use it for any purpose or disclose its content to any person, but delete this message and any attachments from your system. Astrium disclaims any and all liability if this email transmission was virus corrupted, altered or falsified.
Astrium SAS (393 341 516 RCS Paris) – Capital: 16.587.728 EUR – Siège social: 6 rue Laurent Pichat, 75016 Paris, France
URL: <http://lists.rtems.org/pipermail/users/attachments/20080318/701da7f0/attachment.html>
