Rtems provided by gaisler and modifications ?
Jiri Gaisler jiri at gaisler.com
Tue Mar 18 16:23:15 UTC 2008
Have you added ethernet emulation to tsim? Otherwise the networking
code will definitively not work ...
Jiri.
Moro, Pierre wrote:
> Hi everyone,
> Does someone knows how different is the rtems provided by gaisler for
> leon3 boards on their website (4.7.99.2) is really different than the
> one that can be obtained via rpms ?
> In particular, I have some troubles with the
> rtems_bsdnet_initialize_network function that runs forever when loaded
> with the simulator tsim-leon3 (I hope that my problem is not due to the
> tsim)
> But, I can't say more since I have precompiled cpukit and I can't even
> put some printf (or printk ? btw, what is printk?) in the differents
> functions to see what kind of functions are called.
> I've read a few topics on similar problems on this mailing list, and I
> already tried to "pack" structures in ip_var.h.
> I used the bsp provided by gaisler for leon3.
> And now I'm out of ideas ...
> Thx in advance
> Pierre
> Pierre Moro, ASTRIUM ST
> Tel: +33 (0)1 39 06 72 64      Fax: +33 (0)1 39 06 27 97
> Site:* LES MUREAUX* BD: *19* Floor: *1* Room: *141*
> Ce courriel (incluant ses éventuelles pièces jointes) peut contenir des
> informations confidentielles et/ou protégées ou dont la diffusion est
> restreinte. Si vous avez reçu ce courriel par erreur, vous ne devez ni
> le copier, ni l’utiliser, ni en divulguer le contenu à quiconque. Merci
> d’en avertir immédiatement l’expéditeur et d'effacer ce courriel de
> votre système. Astrium décline toute responsabilité en cas de corruption
> par virus, d’altération ou de falsification de ce courriel lors de sa
> transmission par voie électronique.
> This email (including any attachments) may contain confidential and/or
> privileged information or information otherwise protected from
> disclosure. If you are not the intended recipient, please notify the
> sender immediately, do not copy this message or any attachments and do
> not use it for any purpose or disclose its content to any person, but
> delete this message and any attachments from your system. Astrium
> disclaims any and all liability if this email transmission was virus
> corrupted, altered or falsified.
> Astrium SAS (393 341 516 RCS Paris) – Capital: 16.587.728 EUR – Siège
> social: 6 rue Laurent Pichat, 75016 Paris, France
> rtems-users mailing list
> rtems-users at rtems.com
