Get the output of a program in a file using QEmu
Jean-Claude Grange lebauce at free.fr
Fri Mar 21 14:55:20 UTC 2008
Hello,
Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked just fine.
I'm really interested in your patch, Joel. Are you going to commit it
soon ? Or would you mind sending your patch to me so that I can test it.
Thanks
See you
Le 17 mars 08 à 19:47, Joel Sherrill a écrit :
> Jean-Claude Grange wrote:
>> Hello,
>> Thanks for your answer. I'll try that.
>> But I wonder if it's possible to do it without modifying the
>> program ?
> Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
> command line and the console will move to the serial port.
> This is how I run RTEMS and GCC tests in an automated
> fashion.
> I discovered another nice qemu option --no-reboot which
> exits when the simulated PC does a reset.  This means you
> get a single run of the application and then it exits.  I have
> a pending patch in my tree to make the BSP reset on
> application exit or exception without waiting for a human
> to press a character.  This sped up the gcc test runs
> by a large factor since they have >50K tests.
> --joel
>> José Marinho <zemanel at gmail.com> wrote:
>>> you can allways create a file, format it to a specific fylesystem
>>> and pass
>>> it to qemu as an hard drive, and tell the rtems program to create
>>> and write
>>> in a file in that hard drive. and then you can mount that file
>>> with loop
>>> device and access it and get the output file. that's the approach
>>> that I'de
>>> take. Hope that's usefull to you
>>> José Marinho
>>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr> wrote:
>>>> Hello,
>>>> I'm sorry if this is a stupid question but I've searched on the
>>>> mailing
>>>> list and
>>>> didn't find an answer.
>>>> I'm trying to get the output of a RTEMS program (for example the
>>>> Hello
>>>> from the
>>>> samples testsuite) using QEmu, into a file. I'm using the
>>>> command (on
>>>> Linux) :
>>>> qemu -nographic -serial file:output.txt -boot a -fda myimage.img
>>>> -hda
>>>> fat:.
>>>> but I don't get anything in the 'output.txt' file. I also tried -
>>>> serial
>>>> /dev/ttyS* and with the -monitor stdio option but I still have
>>>> nothing. I
>>>> must
>>>> be doing something wrong.
>>>> I would really appreciate your help.
>>>> Thank you
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </img>
> Joel Sherrill, Ph.D.             Director of Research & Development
> joel.sherrill at OARcorp.com        On-Line Applications Research
>   Support Available             (256) 722-9985
