Get the output of a program in a file using QEmu
Fri Mar 21 15:43:14 UTC 2008
Jean-Claude Grange wrote:
> Hello,
> Thank you all for answers. USE_COM1_AS_CONSOLE =1 worked just fine.
> I'm really interested in your patch, Joel. Are you going to commit it
> soon ? Or would you mind sending your patch to me so that I can test it.
I am off this week and not in the best position to do much more
than email.  I will try to commit it over the weekend or Monday.
I haven't worked out the details of automatically resetting
after an exception.  It seems like the default exception handler
should be in the libbsp/i386/shared directory rather than
in score/cpu.  This would allow it to have an auto-reset option.
--joel
> Thanks
> See you
>>> Hello,
>>> Thanks for your answer. I'll try that.
>>> But I wonder if it's possible to do it without modifying the
>>> program ?
>> Define USE_COM1_AS_CONSOLE =1 on the RTEMS configure
>> command line and the console will move to the serial port.
>> This is how I run RTEMS and GCC tests in an automated
>> fashion.
>> I discovered another nice qemu option --no-reboot which
>> exits when the simulated PC does a reset.  This means you
>> get a single run of the application and then it exits.  I have
>> a pending patch in my tree to make the BSP reset on
>> application exit or exception without waiting for a human
>> to press a character.  This sped up the gcc test runs
>> by a large factor since they have >50K tests.
>> --joel
>>> José Marinho <zemanel at gmail.com> wrote:
>>>> you can allways create a file, format it to a specific fylesystem
>>>> and pass
>>>> it to qemu as an hard drive, and tell the rtems program to create
>>>> and write
>>>> in a file in that hard drive. and then you can mount that file
>>>> with loop
>>>> device and access it and get the output file. that's the approach
>>>> that I'de
>>>> take. Hope that's usefull to you
>>>> José Marinho
>>>> On 16/03/2008, Jean-Claude Grange <lebauce at free.fr> wrote:
>>>>> Hello,
>>>>> I'm sorry if this is a stupid question but I've searched on the
>>>>> mailing
>>>>> list and
>>>>> didn't find an answer.
>>>>> I'm trying to get the output of a RTEMS program (for example the
>>>>> Hello
>>>>> from the
>>>>> samples testsuite) using QEmu, into a file. I'm using the
>>>>> command (on
>>>>> Linux) :
>>>>> qemu -nographic -serial file:output.txt -boot a -fda myimage.img
>>>>> -hda
>>>>> fat:.
>>>>> but I don't get anything in the 'output.txt' file. I also tried -
>>>>> serial
>>>>> /dev/ttyS* and with the -monitor stdio option but I still have
>>>>> nothing. I
>>>>> must
>>>>> be doing something wrong.
>>>>> I would really appreciate your help.
>>>>> Thank you
>>>>> _______________________________________________
>>>>> rtems-users mailing list
>>>>> rtems-users at rtems.com
>>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>>> <img> http://www.deec.uc.pt/common/img/deezoom.gif </img>
>> Joel Sherrill, Ph.D.             Director of Research & Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>   Support Available             (256) 722-9985
