GSOC Replies
Wei Shen
cquark at gmail.com
Mon Mar 24 16:24:31 UTC 2008
Hi Joel, Ray, and all,
I know you are rather busy to reply all the mails, but if it does not
bother too much, can I request for some comments on my previous
investigation on FIFOFS (see attachment).
Thanks,
Wei Shen
On 3/22/08, Wei Shen <cquark at gmail.com> wrote:
> On 3/21/08, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> I am torn between a dedicated filesystem and adding a filesystem to the
> IMFS. The dedicated filesystem makes sense and is cleaner./ If you
> don't want this capability, don't mount it.
> Make sure about the pipe() and mkfifo() calls. Careful reading of the
> opengroup standard may force a decision. I hope we can get away with the
> dedicated filesystem. It sounds cleaner and easier to drop out.
Today, I studied the RTEMS FS and IMFS implementation. Seems hard to
implement FIFO as a virtual fs, for the lack of a complete VFS layer,
especially a VFS inode abstraction in RTEMS.
If we want to make FIFOFS entirely independent of the host FS (e.g. IMFS)
which a fifo file resides, we would have to:
1) define a new data-structure for FIFO file-nodes, which repeats many
identical fields (atime, uid, ...) with host FS structures (e.g. jnode in
IMFS).
This is required because otherwise the file handers of FIFOFS can not
understand the node_access structure passed to them from the FS interface.
2) reimplement a full set of FS handlers.
Since filenode structure is changed, no handler of the host FS can be used
any more.
3) hook the host fs (in many places) to add special handling for FIFO files.
An OS with a VFS inode abstraction needs not to do all these, because FIFOFS
can then share the common inode structrure and many FS handlers (i.e. inode
operations) with host FSes, and the VFS layer is respossible for
maintaining inode attributes. Usually, only needs to hook a few FS routines
like mknode and open.
An alternative implementation is to design a FIFO interface to FS and
implement part of file handlers demanded (open, write, rmnod, ...).
FSes should provide a set of handlers (as IMFS currently done for device
files) specific to FIFO files that invoke the FIFO interface and maintains
filenode (e.g. jnode) states. Part of the FIFO handlers (that do not alter
filenode states) can be directly plugged into the file handler table of the
host FSes.
By so, FIFO can still be encapsulated into a independent module, but only
requires a little modification on FS code.
The open project page suggests: "For unnamed pipes, we could create a named
FIFO using a temporary name. ... place them possibly in a special
directory". I originally think it is unnecessary, however, also due to the
lack of a VFS inode structure, it seems to become a problem, for we have to
create a jnode (in the case of IMFS) to preserve file states, and maybe the
easiest way to acheive that is creating a IMFS file.
Comments are always welcome.
Thanks,
Wei Shen
URL: <http://lists.rtems.org/pipermail/users/attachments/20080325/1fb275da/attachment.html>
