GSOC Replies
Mon Mar 24 18:02:44 UTC 2008
Wei Shen wrote:
> Hi Joel, Ray, and all,
> I know you are rather busy to reply all the mails, but if it does not
> bother too much, can I request for some comments on my previous
> investigation on FIFOFS (see attachment).
> Thanks,
> Wei Shen
> On 3/22/08, *Wei Shen* <cquark at gmail.com <mailto:cquark at gmail.com>> wrote:
>     O
> n 3/21/08, *Joel Sherrill* <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
>     I am torn between a dedicated filesystem and adding a filesystem
>     to the
>     IMFS.  The dedicated filesystem makes sense and is cleaner./  If you
>     don't want this capability, don't mount it.
>     Make sure about the pipe() and mkfifo() calls.  Careful reading of the
>     opengroup standard may force a decision.  I hope we can get away
>     with the dedicated filesystem.  It sounds cleaner and easier to
>     drop out.
> Today, I studied the RTEMS FS and IMFS implementation. Seems hard to
> implement FIFO as a virtual fs, for the lack of a complete VFS layer,
> especially a VFS inode abstraction in RTEMS.
> If we want to make FIFOFS entirely independent of the host FS (e.g.
> IMFS) which a fifo file resides, we would have to:
> 1) define a new data-structure for FIFO file-nodes, which repeats many
> identical fields (atime, uid, ...) with host FS structures (e.g. jnode
> in IMFS).
> This is required because otherwise the file handers of FIFOFS can not
> understand the node_access structure passed to them from the FS interface.
> 2) reimplement a full set of FS handlers.
> Since filenode structure is changed, no handler of the host FS can be
> used any more.
> 3) hook the host fs (in many places) to add special handling for FIFO
> files.
> An OS with a VFS inode abstraction needs not to do all these, because
> FIFOFS can then share the common inode structrure and many FS
> handlers (i.e. inode operations) with host FSes, and the VFS layer is
> respossible for maintaining inode attributes. Usually, only needs to
> hook a few FS routines like mknode and open.
If you implemented this as a special file system type, do you think it
is feasible
as a GSOC project to extra the common inode processing code into shared
code?
I don't know if this makes it a real VFS structure or just a shared set
of methods
that makes filesystem implementation easier.
> An alternative implementation is to design a FIFO interface to FS and
> implement part of file handlers demanded (open, write, rmnod, ...).
> FSes should provide a set of handlers (as IMFS currently done for
> device files) specific to FIFO files that invoke the FIFO interface
> and maintains filenode (e.g. jnode) states. Part of the FIFO handlers
> (that do not alter filenode states) can be directly plugged into the
> file handler table of the host FSes.
> By so, FIFO can still be encapsulated into a independent module, but
> only requires a little modification on FS code.
This would be easy and could be a first step if you went to
refactoring/extracting
common inode processing.
> The open project page suggests: "For unnamed pipes, we could create a
> named FIFO using a temporary name. ... place them possibly in a
> special directory". I originally think it is unnecessary, however,
> also due to the lack of a VFS inode structure, it seems to become a
> problem, for we have to create a jnode (in the case of IMFS) to
> preserve file states, and maybe the easiest way to acheive that is
> creating a IMFS file.
I agree with you and after some thought think it might be worth pursuing
a FIFOFS ONLY if you undertake to extract IMFS code and arrange to share it.
--joel
> Comments are always welcome.
> Thanks,
> Wei Shen
