gcc-4.3.0/ppc32 inline assembly produces bad code
Till Straumann strauman at slac.stanford.edu
Wed Mar 26 16:25:05 UTC 2008
As of gcc-4.3.0 one of my drivers stopped working.
I distilled the code down to a few lines (see below).
The output of
    gcc-4.3.0 -S -O2 -c tst.c
and
    gcc-4.2.3 -S -O2 -c tst.c
is attached. The code generated by gcc-4.2.3 is as expected.
However, gcc-4.3.0 does not produce a correct result.
Is my inline assembly wrong or is this a gcc bug ?
(If the memory input operand to the inline assembly
statement is omitted then everything is OK).
Please CC-me on any replies; I'm not subscribed to the gcc list.
WKR
-- Till
Test case; C-code:
/* Powerpc I/O barrier instruction */
#define EIEIO(pmem) do { asm volatile("eieio":"=m"(*pmem):"m"(*pmem)); }
while (0)
 * Reset a bit in a register and poll for it to be set by the hardware
void
test(volatile unsigned *base)
    volatile unsigned *reg_p = base + IEVENT_REG/sizeof(*base);
    unsigned           val;
    /* Clear bit in register by writing a one */
    *reg_p = IEVENT_GRSC;
    EIEIO( reg_p );
    /* Poll bit until set by hardware         */
    do {
        val = *reg_p;
        EIEIO( reg_p );
    } while ( ! (val & IEVENT_GRSC) );
Assembly code produced by gcc-4.3.0:
    .file   "tst.c"
    .gnu_attribute 4, 1
    .gnu_attribute 8, 1
    .section    ".text"
    .align 2
    .globl test
    .type   test, @function
test:
    li 0,256
    mr 9,3
/*** ^^^^^^^^^ NOTE: base address copied into R9 ***/
    stw 0,16(3)
 # 21 "c.c" 1
    eieio
 # 0 "" 2
.L2:
    lwz 0,0(9)
/*** ^^^^^^^^^ BAD: R0 = *base instead of *reg_p ***/
 # 26 "c.c" 1
    eieio
 # 0 "" 2
    andi. 11,0,256
    beq+ 0,.L2
    blr
    .size   test, .-test
Assembly code produced by gcc-4.2.3:
    .file   "tst.c"
    .section    ".text"
    .align 2
    .globl test
test:
    li 0,256
    addi 9,3,16
/*** NOTE: R9 = base + <IEVENT_REG offset> ***/
    stw 0,16(3)
    eieio
.L2:
    lwz 0,0(9)
/*** GOOD: R0 = *reg_p                     ***/
    eieio
    andi. 11,0,256
    beq+ 0,.L2
    blr
    .size   test, .-test
    .ident  "GCC: (GNU) 4.2.3"
