ENABLE_SIS_QUIRKS overwrites work-space area (4.6.6)
Aleix Conchillo Flaqué aconchillo at ieec.cat
Fri Mar 28 16:12:07 UTC 2008
Hi,
in /c/src/lib/libbsp/sparc/shared/start.S, the ENABLE_SIS_QUIRKS code
is executed after having configured the stack pointer according to the
work-space are and thus overwriting it. The ENABLE_SIS_QUIRKS code
should be located, as in previous versions, before using the stack
pointer.
If I have not missed anything, the attached patch solves this problem
in 4.6.6 (and 4.6.5).
Aleix
Type: text/x-diff
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20080328/193cb20d/attachment.bin>
