Google summer of code
Kliakhandler Kosta
public at kosta.tk
Fri Mar 28 20:00:44 UTC 2008
Thanks for your comments!
Quoting Joel Sherrill <joel.sherrill at oarcorp.com>:
> Kliakhandler Kosta wrote:
>> Hello,
>> I'm interested in working on RTEMS for Google summer of code. I'm
>> particularly interested in working on tinyRTEMS and porting it to
>> an lpc2138 board (which I posseess). I never used it (RTEMS), but
>> I am developing an application on the mentioned board and although
>> I didn't plan to use an rtos yet, the project will in general
>> benefit from it.
> OK. There has been a lot of discussion on TinyRTEMS this week so I
> am not going to repeat any of that. It's Friday and I am tired. :)
I joined the list only a couple of days ago so I didn't see it, but
I will definitely take a read it when I find the archives... (while
writing this email I found it :)
> Some suggestions. You are proposing an lpc2138 BSP. So I see
> a few obvious tasks in your proposal:
> + BSP for real hardware
> + BSP runs on Skyeye simulator
AFAIK skyeye doesn't run lpc21xx yet - if so, that will probably be
another task.. I haven't worked with skyeye either yet - Is there a
significant difference (for rtems or otherwise) for code which runs on
skyeye as opposed to code which runs on HW?
> From a TinyRTEMS perspective, there are lots of ideas and you will have to
> decide which tickle your fancy. How much memory is available on your
> target hardware?
I'm thinking about what I want to do right now. I was hoping for
some guidance about which features seemed most useful to the developers.
> Do you have any display option? If so, consider adding Microwindows/Nano-X
> support to your proposal.
I have an lcd character screen - I don't know whether it qualifies
as a "display", but I certainly will consider it.
>> If possible, I would like some guidence regarding what is
>> important, times, and general advice regarding writing a proposal
>> for this project.
> The student proposal deadline is approaching soon but you still have time
> to make a proposal. I think there are guidelines at the SOC site on what
> outline to follow. SOC has a schedule and your proposal should track that
> with activities in stages that make sense based upon that.
I realized that - I meant it in an rtems centric way.. I realise
that times for developing the various projects differ between
developers, but I was hoping for some suggestions on the projects to
take, so that my proposal wouldn't turn out unacheivable due to a
massive amount of work on the one hand, or "unsatisfactory" because I
proposed things which were too small... I guess what's left to do is
to write a proposal and hope I'll have time to revise it according to
suggestions...
> Maybe one of the others can post some helpful links.
>> Thanks in advance,
>> Kosta.
>> Kliakhandler Kosta.
>> Website: http://www.kosta.tk
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20080328/bbd738d6/attachment.html>
Name: not available
Type: application/pgp-signature
Desc: PGP Digital Signature
URL: <http://lists.rtems.org/pipermail/users/attachments/20080328/bbd738d6/attachment.bin>
Name: not available
Type: application/pgp-keys
Desc: PGP Public Key
URL: <http://lists.rtems.org/pipermail/users/attachments/20080328/bbd738d6/attachment-0001.bin>
